Home > In Car Electronics > Spotlight problem
Page 2 of 2 <12
Martin
Site Admin
As above, the TR spot light relay (likely to be a yellow coloured cube relay) is enabled by the column switch with a "2" on it and the voltage sensitive switch.
Track down the tall yellow relay-type module labelled "Voltage Sensitive Switch":
This might be behind the speedo/instrument pack, it depends how the TR models had their extra wiring added.
Not sure where in Buckinghamshire you are but I'm near Banbury if you need help diagnosing the issue.
(Edited)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #857185 21st Sep 2020 10:07am
Martin
Site Admin
Looking again at your fuse box photo, I think it's likely that the two green relays are those for the spot lights. The wire colours coming out appear to be blue with stripes so probably headlamp/spot related.
If you can unclip those relay bases from the fuse box and photograph the bottom, showing the wire colours coming out, I can advise how to test the lamps and relays.
Martin  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #857186 21st Sep 2020 10:19am
Arcticrover
United Kingdom 2002 Defender 90 2.5 TD Tomb Raider LE Bonatti Grey
Post #857400 22nd Sep 2020 11:22am
Martin
Site Admin
Sorry I meant the wires coming out of the sockets Embarassed  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #857402 22nd Sep 2020 11:41am
Arcticrover
My fault, read that wrong
Post #857441 22nd Sep 2020 2:58pm
mk1collector
That blue and purple looks in a very bad state. I’d try cleaning it up and see if that makes a difference. Ray
My build thread
Post #857443 22nd Sep 2020 2:59pm
Martin
Site Admin
Looks like some corrosion on that relay terminal - what does it look like from the side the relay plugs in? Might be worth installing/removing/installing a few times to clear the terminal of corrosion.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #857444 22nd Sep 2020 2:59pm
Martin
Site Admin
Does the wiring from that relay attach to the other green one next to it?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #857447 22nd Sep 2020 3:05pm
Arcticrover
Came down with a head cold, I'll get back at it tomorrow, again thanks to everyone for all the help. This forum is great with some great people!!
Post #857678 23rd Sep 2020 5:17pm
Quidgebo
United Kingdom 2001 Defender 90 Td5 Tomb Raider LE Bonatti Grey
Was no news good news?
Hi there.
Just really curious, did cleaning up that relay help or was the issue ever found?
I have the seemingly same behaviour… yet this post has given some vital clues at least.
Post #1026744 3rd Mar 2024 11:35pm
JoolsB
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
If they’ve been working fine and stopped and the fuse is ok, with current at the unit then try moving the earth and see if that gets it.
Post #1029317 25th Mar 2024 11:00pm
Quidgebo
We’ve not long took ownership so they haven’t worked for us - yet I’ve also found a corroded connector under the bonnet before where it heads up the roll cage to the roof (plus tape wrapped wires). So know what I’m doing for Easter. Start at the fuse box and trace current downstream until I find and fix all I can.
Post #1029322 26th Mar 2024 12:29am
JoolsB
Good luck, it’s the wiper mechanism in its entirety for me Big Cry
Post #1029368 26th Mar 2024 3:33pm
Page 2 of 2 <12
