![]() | Home > Puma (Tdci) > Defender Puma No Start |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 628 ![]() ![]() |
Hi... Does your tank mounted pump run when you switch on the ignition?.. It can normally be heard
And it would be handy to know what your rail pressure is doing when you do try and start it.. If you run something like the torque app, that should tell you👍 |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3480 ![]() ![]() ![]() |
Do you have any fault codes?
Regarding fuel on the low pressure side, there is a schrader valve, normally covered by a green cap. Try pressing the valve and see if fuel is coming out. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Lcchn Member Since: 21 Mar 2024 Location: Germany Posts: 2 ![]() ![]() ![]() |
I can hear the low pressure pump running and my fuel rail pressure is about 185-200 bar whilst cranking.
![]() Click image to enlarge If I crank for like 20 seconds I get a fault code. ![]() Click image to enlarge And when I press the schrader valve there is fuel coming out with a good amount of pressure. I also took off one of the lines from the rail to the fuel injectors. There was some diesel in the line but there was non coming out of the rail while cranking. |
