![]() | Home > Td5 > Defender Td5 - Front left brake not working, oil everyone |
34064 Member Since: 12 Dec 2023 Location: South Central Posts: 225 ![]() ![]() ![]() |
First of all you'll need to work out where the oil or grease is coming from probably a hub seal or swivel seal leaking and getting thrown around.
When you say holding on a hill do you mean on the hand brake or holding the brake pedal down? 110 Td5 Ex Utilities slowly converting into a pop top camper one day Build thread:https://www.defender2.net/forum/post1024784.html#1024784 |
JoshCox Member Since: 21 Mar 2024 Location: Cape Town Posts: 2 ![]() ![]() ![]() |
With the brake pedal it struggles to hold on a relatively steep hill
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 804 ![]() ![]() ![]() |
Defender brakes are actually pretty good.... Sounds like you need to do a complete inspection and overhaul of the brake system.
CanDef Member Since: 03 Apr 2024 Location: offroad Posts: 3 ![]() ![]() |
Brakes stop the car with friction. Lubricants reduce friction. Check out the leak first. Degrease the area with brake wash and try it. Be sure that its not a brake fluid leak before driving. Could be dangerous.
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 335 ![]() ![]() ![]() |
The tell-tale sign will be if the brake fluid level has dropped. If it hasn't you're looking at axle/hub oil seal or swivel seal. As has already been mentioned if you can eliminate the brake fluid leak you must clean everything and replace contaminated brake pads. Check the front axle oil level as this is fairly easy to do, if it's very low suspect oil seal. Checking the grease in the swivel is harder. Good luck and be careful. |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2308 ![]() ![]() ![]() |
Inner hub seal gone.
