Home > Puma (Tdci) > Speedometer adjustment |
nikojo Member Since: 05 Aug 2011 Location: Madrid Posts: 75 |
I'm running smaller tires and it's thrown the speedometer off by 10MPH.
Does anyone know how to adjust this??? |
27th Nov 2011 7:40am |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
(a) what tyres and wheels are you now running and what Defender do you have,
(b) why post this 3 times |
27th Nov 2011 8:38am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
theres 3 different sizes SEB 2.4 90 XS
27th Nov 2011 9:55am |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
how do you alter those settings? |
27th Nov 2011 11:08am |
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 |
I suspect the answer is visit a dealer |
27th Nov 2011 11:56am |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
@T1G UP,
a nanocom or MSV will allow you to do this, though the stored tyre sizes are minimal and relate to LR stock sizes and not after market larger tyres. @Sockpuppet, if you do it yourself then you know for a fact it was done correctly. |
27th Nov 2011 3:49pm |
I'm running 245/75 on Wolf wheels (16"). They are Cooper M&S for light truck. Sorry if it posted 3 times.....I might have a twitchy finger from too much coffee. I don't have access to a dealer nearby so I may be screwed. |
27th Nov 2011 6:43pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
With that tyre size you will only be 2.4 mph under from a stock tyre of 235/85/16 NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
27th Nov 2011 7:04pm |
how bigs a 285.75 in MM's then? |
27th Nov 2011 7:05pm |
Here Brian, play with this
The diameter of a 285/75/16 is 833.9mm http://www.miata.net/garage/tirecalc.html NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
27th Nov 2011 7:08pm |
I agree with everything said but it is "off" almost twice that amount.
Before I installed the tire I noticed it was fairly smaller than what I "calculated" based on the stated size. Apparently there are differences from manufacturer to manufacturer. This is on a Puma. |
27th Nov 2011 7:35pm |
I use it already Karlos, from a post you did last year.
27th Nov 2011 7:36pm |
2619.8mm |
27th Nov 2011 7:38pm |
27th Nov 2011 7:42pm |
