![]() | Home > Maintenance & Modifications > Installed the Non-retur valve for the Webasto (water heater) |
![]() Click image to enlarge ![]() Following the Webasto scheme ![]() Click image to enlarge Here my results ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
Looks good - is the Webasto up and running now?
Not yet, I need to make the fuel connection from the tank to the fuel pump...... Probably I'do a hole with cover for access to the fuel sender from the Defender roof. In this way I do not need to remove the fuel tank. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
ehmmm floor .... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
