Home > Maintenance & Modifications > Trolley Jack
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
Trolley Jack
Alas my old trolley jack has died Sad
To be fair it was rather old. I bought it when I had a Lotus and it was a light weight low entry jack. Not ideally suited to a Defender. A combination of age and abuse has seen it off. I do have a massive 3 ton high lift trolley jack but it's a bit cumbersome in my small workshop.
I do have a compressor so I could go for one of those air bottle jacks or just a regular pump handle bottle jack.
What does everybody use for their Defender?
Post #1027815 12th Mar 2024 3:50pm
Ianh
I use two jacks, a sealey high lift 3 ton jack that I use with their x137 cross beam adapter when jacking the axle to keep vehicle level. Plus a low profile Arcan 3 ton trolly jack for the defender and other vehicles.
The most robust jack is the Arcan, which has worked with zero issues over 20 years, the sealey needed new seals after 5 years, however I can’t use the cross beam adapter with the Arcan , hence have two jacks for home use.
I got my Arcan from costco a great price then, they still sell the 2.750 ton one at a reasonable price.
Both are reasonably big and heavy ( a bit like me Very Happy ) but ideal for the defender.
But if you want the ultimate defender jack, go for the one blackwolf has....I bet he will show you a pic, if he spots this topic, it’s a thing of beauty.
Edit:- This is the trolley jack topic, on the page where their are pics of BW’s pro Eagle https://www.defender2.net/forum/topic79837...p;start=45
Post #1027823 12th Mar 2024 4:21pm
hank
I've got one of these. Picked it up off Facebook for £20
https://www.machinemart.co.uk/p/clarke-ctj...lley-jack/ > 110 XS Double Cab
Post #1027825 12th Mar 2024 4:28pm
Two-ton Pro-Eagle (foreground). Lesser jacks are available. You may want to take a look at this thread which was very similar.
Post #1027832 12th Mar 2024 4:57pm
TexasRover
I have an Omega 28030-PU, once bought in the UK. It is the usual 3 ton jack but after many years still perfect. What I like about it and why I bought it is that it has PU (poly urethane?) wheels which makes riding it around so much nicer and quieter.
Post #1027835 12th Mar 2024 5:07pm
Bluest
I noticed there is a JCB branded jack that looks like a copy of the off-road one Blackwolf has.
https://jcb-tools.co.uk/jcb-2-5-tonne-off-...-th32506s/ 2007 110 TDCi Station Wagon XS
Post #1027838 12th Mar 2024 5:38pm
Interesting, not seen the JCB one before.
Post #1027846 12th Mar 2024 7:03pm
They’ve been expanding their range quite a lot in the last few years. Thumbs Up No Guts, No Glory.
Post #1027851 12th Mar 2024 7:17pm
steveww
That’s the big one I’ve got.
I like the look of the JCB one. Time to check the Defender piggy bank.
Post #1027854 12th Mar 2024 7:53pm
34064
United Kingdom 2003 Defender 110 Td5 HT Alaska White
I bought a Halfords advanced trolley jack a few years ago it's brilliant as it has a foot pump aswell and its quick to lift and will lift Defenders and Discoveries off the ground easily aswell as get under low cars if needed. But the best bit is it has Polyurethane wheels so it's alot quieter and doesn't sound like a 747 taking off when you move it 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784
Post #1027873 13th Mar 2024 6:15am
kenzle8a
This has to be one of the best value jacks about at the moment.
I got it for my L322 and it didn't break a sweat lifting 2.7 tonnes of Range Rover. I'm 99% sure its made by Arcan (who make the costco ones) as I have a 2.5 tonne Arcan jack and the fittings are the same as is a few of the parts.
https://www.halfords.com/tools/garage-work...63118.html
Post #1027886 13th Mar 2024 8:27am
NickMc
The JCB one has twin tailpipes though Laughing
Post #1027933 13th Mar 2024 3:11pm
I was trying to figure out the twin exhausts and finally it dawned on me that they are the risers for the lifting cup.
Post #1027941 13th Mar 2024 4:14pm
Shafski
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Ooo this is like tool porn!
Like others, I have 2..
The Clarke 3t (had for 15+) years, also used with a Sealey Cross Beam adapter for that level lift.. - “the Daddy”
And…
I have a beautiful Blue Point SNX2ALTJ Aluminium Floor Jack..
It’s a quick lift and is just fab.. bought in a moment of eBay weakness as the Clarke refused to fit under my RIP’d Z3 Whistle Rolling with laughter Shafski
_________________________________________
2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E
Post #1027958 13th Mar 2024 5:48pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Bought a 3ton Sealey jack late 90s early 00s and still using it now. It did start leaking from the pumping piston in the early years which the official seal kit failed to fix. I tried a second time with quality o-rings from work (I work in the semiconductor industry so everything is top quality ISO traceable) and it has worked perfectly ever since.
Perfect jack, just about low enough for 'normal' cars but also easily man enough to lift a tall Landrover or loaded 3.5T van.
Post #1027986 13th Mar 2024 10:14pm
