![]() | Home > Td5 > What is normal range for the waste gate modulation %? |
mturri Member Since: 13 Jul 2010 Location: All over Posts: 33 ![]() ![]() ![]() |
Perfectly normal, that's about the maximum fraction of exhaust gas flow the system is designed to recirculate. Toasted MAF. Wild guess is fuel delivery issue (fuel pump or FPR) but a long shot. Having the luxury of a Nanocom further troubleshooting is possible. Should replace or unplug the MAF for starters (ideally the former). A bad MAF can cause non-responsiveness/hesitation issues. HTH Matt 24 yrs of Td5 ownership D110 Td5 MY06 fully tuned up ex-D2 Td5 MY04 Auto ex-D110 Td5 MY00 ex-D2 Td5 MY00 ex-D2 Td5 MY99 ex-D1 300Tdi MY89 ex-D90 200Tdi MY87 |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 642 ![]() ![]() ![]() |
Waste gate modulator is not EGR. It is to control turbo pressure. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 192 ![]() ![]() ![]() |
EGR long gone
Thanks will have a look in that direction. Maf sensor is on the way so will see how it goes. Tried to recreate the issue yesterday, but didn't occur where it usually would (long uphill section near me) will try again when I've swapped the MAF. |
Totally right MadTom, thanks for pointing that out. Clearly stated by OP yet took it in all wrong... must be my advanced age and decaying cognitive abilities... Aside, Balmy, WGM % is duty cycle in terms of pulse width modulation, not WG opening. 40% is about the maximum you'll see in practice. 24 yrs of Td5 ownership D110 Td5 MY06 fully tuned up ex-D2 Td5 MY04 Auto ex-D110 Td5 MY00 ex-D2 Td5 MY00 ex-D2 Td5 MY99 ex-D1 300Tdi MY89 ex-D90 200Tdi MY87 |
Does this mean it's the signal I'm looking at, and not the position? Ie, it could appear normal even if the gate is sticky? New MAF is in... much improvement in power pick up Jury still out on the "bubble" under the accelerator as I haven't had a chance to recreate it (I have tried but not in the usual uphill drag where I always notice it) |
Waste gate modulator is used only on Discovery 2 TD5, Defender TD5 has just a straight pipe. But software in engine ECUs are nearly the same, so both can control the modulator or at least send out some live data. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
So just done a 500 mile run up and down the m1 at times up to 75, and absolutely no sign of the bubble, so I guess it was MAF related
![]() Even better it rained most of the way and i have no water in the air system at all, so 2 problems cured. It has however developed a clank which I think is prop shaft related ![]() |
