Home > Wheels & Tyres > Wheel nut thread |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
Googled Defender wheel stud size. First hit was Wrightons. which I nicked this from Brendan |
25th Nov 2011 11:44pm |
It's M16 x 1.5. Darren
25th Nov 2011 11:45pm |
Too slow Darren
Brendan |
25th Nov 2011 11:46pm |
Ha! I found the same reference as you but was cross-checking with another source It's funny how often the answer is Google though Darren
25th Nov 2011 11:51pm |
MuddyMarky Member Since: 01 Feb 2010 Location: Oxfordshire Posts: 548 |
Thank you guys....hadn't even thought if google! First thought was here (I reckon that's a good thing?)
Mark 2011 110 XS DC Stornoway Grey |
26th Nov 2011 10:47am |
RFT Member Since: 13 Nov 2010 Location: Cheshire Posts: 683 |
M16x1.5 is difficult to get hold off, the usual size for studding etc is M16x2.
I gave up looking and use M16x2 for my spare wheel mount and I'm meant to be an Engineer, but we rarely use metric threads because they are the product of a Comittee designing something. 130 Puma HCPU with an Artica 240LR Demountable Camper |
26th Nov 2011 11:38pm |
m16 x 1.5 threaded bar available here
Brendan |
27th Nov 2011 12:05am |
It's black bar, not Galv or plated. 130 Puma HCPU with an Artica 240LR Demountable Camper
27th Nov 2011 12:14am |
So why didn't you make your own, or use a contact to run one off for you? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
27th Nov 2011 9:32am |
I didn't need to get anything in the end! I just shifted the wheel over very slightly in the back so the bar now goes through one of the wheel nut holes, rather than through the middle & using the circular plate to hold it. Then just used the locking wheel nut to hold it in place. I hope it doesn't upset the balance too much!
Mind you, maybe it'll sort out the leaning to one side my truck has at the moment Mark 2011 110 XS DC Stornoway Grey |
27th Nov 2011 10:03am |
