Home > Maintenance & Modifications > clutch won't disengage |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Hi all
So driving home the other evening and clutch started feeling funny. Stopped at a traffic light dipped the clutch but engine laboured and we crept forward. Foot was hard on the floor but could feel the clutch engaging and then fully engaged even with foot on the floor. Dull. Basically the clutch wasn't disengaging. Cue a very boring drive home with gear changes that make you go oooooff. Got home looked and the flexible rubber hose which goes from the hard piping on the bulkhead to the hard pipework on the gearbox had rubbed through and all the fluid come out. Annoying but yay a smoking gun at least! So this morning changed it and bled it so all good. However clutch pedal goes 75% to the floor before it takes any "weight" and clutch is not disengaging. It was fine before the leak so I see no reason why anything should have changed but am I missing something? Could it just need another bleed? Is it a symptom of a push rod pushing though the clutch fork? Suggestions welcomed. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
10th Mar 2024 12:13pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20516 |
Probably needs re-bleeding, and as such you’ll need some Dot 4 fluid to do so.
The hydraulic pipework needs to be 100% leak proof too, the only issue may be if there was any damage to the internal slave or excess slipping when it was being driven. If it’s had clutch drag that’s fluid leaking, or the slave is non concentric I had that when a clutch spring came out though but in turn messed up the slave. Was there any noises? If not, then you may be okay but if there was any then you could have had a spring come out due to the leak. Hopefully not! As mentioned, you probably have a little bit of air still in there possibly. It can get trapped just before the master cylinder and it only needs to be an air bubble to reduce the clutch throw, and that’s when you’ll get slip with will kill the clutch friction plate. It might pay to unbolt the union attached to the MC, to let the air out then reconnect and re-bleed. Gravity bleed does work well enough, just don’t let it run out of fluid in the MC. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
10th Mar 2024 4:24pm |
P.S. wash off any spills with water asap as it’s corrosive to paint. No Guts, No Glory.
