Home > General & Technical (L663) > 2024 90 gets fold flat rear seat and lifted boot floor |
JustCallMeMac Member Since: 02 Jan 2023 Location: Southampton Posts: 25 |
Thanks for confirming. I've been holding off ordering the 90 until dealer could confirm flat floor option was available.
Can you make the rear entirely flat now, without removing the bench padding / headrests? Did you also get the spare wheel lock supplied by LR or does it come from a third-party? Cheers. |
9th Mar 2024 1:17pm |
Joolroper Member Since: 02 Oct 2022 Location: Bristol Posts: 25 |
Load space now flat as seat bases redesigned to tip forward. Much better!
The wheel lock is a landrover part, I saw it on Facebook defender forum and the dealer got me one (I had to pay extra) |
9th Mar 2024 2:09pm |
DrRob Member Since: 29 Mar 2017 Location: Hampshire Posts: 170 |
How easy and quick is it to remove the tray and replace etc? MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
1974 Series 3 Lightweight = "Millie" Many Range Rovers and Land Rovers over the years 😂 1949 80" - still in family since 1975 |
9th Mar 2024 4:36pm |
Click image to enlarge Very easy, just drops in and seats nicely. It utilises the existing load space cover. You just slot Click image to enlarge it back in. I'm going to leave in place all the time, have put items in the storage area used infrequently. It's now a usable flat space. |
9th Mar 2024 5:25pm |
Is there storage under the original floor too?
Can you post a picture of the inside area of the tray so I can see what sort of compartments there are. Cheers 👍 MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung 1974 Series 3 Lightweight = "Millie" Many Range Rovers and Land Rovers over the years 😂 1949 80" - still in family since 1975 |
10th Mar 2024 9:30am |
Click image to enlarge Click image to enlarge Click image to enlarge There is no space directly below, the jack and wheel lock nut are there. I did get the removable tow hitch stored under the jack as space near battery Click image to enlarge |
10th Mar 2024 9:56am |
Thanks for that.
In that last pic, what is it that I'm seeing between the folded seats, and the back of the front seats and the back of the centre console? Headrests or the bench seat padding? Many thanks. |
10th Mar 2024 9:58am |
Thanks! I’m going to see if the foam tray can come out under the original floor and repack stuff in there. I prefer a bottle jack to those evil factory scissor ones! MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
10th Mar 2024 9:59am |
I see they also supply a wheel changing “stud extension tool” 👍 MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
10th Mar 2024 10:02am |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1106 |
“stud extension tool” ..... may not fit the 18" steels ??
10th Mar 2024 10:08am |
That's the underside of the tipped forward rear seat bases, they now flip up like all other cars and fold forward before rear seat backs fold down. |
10th Mar 2024 12:01pm |
Tobers Member Since: 01 Oct 2023 Location: Skye Posts: 39 |
It does indeed come out, and reveals a load of usable space. I am going to construct a plywood box type thing to go in there. I don’t want to just chuck stuff in the hole as there are a million wires and the MHEV kit, and the suspension air compressor, so I’m going to separate it all off and make a nice fitted box to go in the space. |
10th Mar 2024 2:52pm |
10th Mar 2024 2:53pm |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3394 |
How the 90 should’ve been from launch. Hopefully my 24MY year comes with it. 24MY 90 D250 HSE, Tasman Blue
10th Mar 2024 4:32pm |
