Home > Td5 > Strange ECU issue
Joel
United Kingdom 2002 Defender 110 Td5 DCPU Santorini Black
Strange ECU issue
Hi folks,
Friend is having an issue with his TD5, it cranks but won’t start. None of the glow plug or fuel pump relays click on when you crank. The coolant gauge goes into the red. pumping the accelerator 5 times doesn’t do anything.
The ECU when I try and read it with my nanocom says it cannot communicate with the ECU, but it can with the Alarm and ABS ECU. If I put the ECU in my truck, it reads it fine, if I put mine in his truck I get the same unable to communicate. All the fuses and relays are checked good and working, all have power. ECU has power on pin 33
No immobiliser lights, everything looks fine, battery is ok, and it spins over fine.
We are a bit baffled.
Post #1027143 7th Mar 2024 10:47am
kenzle8a
check the fuel cut off switch under the bonnet.
most of your issues happen when thats bad or there's a cut off switch fitted to it for security.
Post #1027144 7th Mar 2024 11:10am
Joel
Been though all those. Everything is good. the fact that the Nanocom cannot read from the ECU just seems odd, even with an inertia switch or fuel cut off I would still expect the ECU to be readable
It worked before he parked it up, he's been away for a week or so and now he has this issue.
Post #1027154 7th Mar 2024 12:25pm
Linds Hanson
Relays under drivers seat either corroaded or bad contact in relay connector
Post #1027156 7th Mar 2024 12:31pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
If you hear click from main relay when ingitinon on, and inmediatelly again, when ignition off, software in ECU does not run. The same is no MIL and GLOW indicators, no fuel pump noise in tank.
If you have tested cut off switch under the bonnet (check also wires to the switch), than ECU is probably not working. Try any TD5 engine ECU - you need at least working MIL and GLOW indicators and running fuel pump. No need to run engine thie way, no need for diagnostics for this basic tests. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1027261 8th Mar 2024 10:32am
