Home > Maintenance & Modifications > Rear door struts |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2904 |
I checked and my kit definitely does not slow! Overtime something would break so I will have to find a solution. Emailed Mud to ask what is normal... Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
4th Mar 2024 7:58pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4223 |
I'll try and video mine next time I'm out with it. I vaguely remember there was more than one revision to the Mud one. 2007 110 TDCi Station Wagon XS
4th Mar 2024 8:24pm |
hamzasikveli Member Since: 05 Mar 2024 Location: Hannover Posts: 1 |
Thanks for information
5th Mar 2024 8:36am |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 571 |
I have one from Mud and it definitely slows as the door reaches fully open.
5th Mar 2024 3:34pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20516 |
Be very careful when drilling the door frame prior to riveting, just a word of warning.
As it’s all too easy to go through the outer door skin on the other side, especially if you happen to have a dull drill bit. Though they can be a little more brittle, I’d go for a brand new HSS Cobalt drill bit, and use tape or a depth stop to ensure it goes though just enough. The steel that the door frame is made of is good quality, it does take a little drilling through but when it does the bit can go straight out the other side and the door skin wouldn’t take much at all to pierce and it is quite close behind. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
I drilled through a small piece of timber first to just expose 5mm of the drill bit as I was concerned of the drill jumping ahead.
Anyway we can blame Charlie for my mistake fitting the strut the wrong way around, although it does appear to slow for him in the video. I have it reversed and it is now behaving correctly. Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
5th Mar 2024 3:40pm |
MCMA - Yes, that’s a good idea using a bit of wood for the drill bit.
On that video, the gas stout on mine is opposite to that in the video, as I found the larger barrel of the gas strut would clash with the door frame, instead on mine the piston rod (silver) type part attaches to the LR tub body. Also, I seem to remember, I didn’t get one of those brackets that attaches to the tub, or it didn’t fit one of the two. And the fixing nearest the tub, had the hex head cap screw in from the top, against the bracket, with the piston pivot just blow the bracket, and then with the nyloc nut at the bottom, using the existing bracket. Keep it nicely lubed too, funny enough I did that just today. It was very strong at first, but it settled down 6 months later. I set it so the spare wheel just cleared by about 1/2” the rear body cappings, so it didn’t hit it when fully opening. Have the new gas struts got a soft opening now, I.e hands free?’I think mine would open quite harsh on its max travel. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
5th Mar 2024 8:58pm |
