![]() | Home > General & Technical (L663) > Very weird problem - dead car |
Can_glu Member Since: 18 Feb 2024 Location: Toronto Posts: 11 ![]() ![]() |
12.3 is a bit low, especially after running for a while. I would check the battery and charging system.
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3011 ![]() ![]() |
l assume it's not like on older vehicles where a low battery will light everything up but the vehicle won't start.
l imagine if the ECU determines that the battery voltage is low it won't turn any systems on? Although l would expect at least a warning on the dash to advise. Some people have had faulty batteries so it might be worth getting the battery checked. |
JackW Member Since: 10 Jan 2017 Location: Roswell, Georgia Posts: 115 ![]() ![]() ![]() |
The battery is a six month old replacement Odyssey battery - but the car died on the road on the way back from the grocery store this evening (in the rain of course). It had to be retrieved on a flat bed wrecker and is at the dealer for inspection and testing tomorrow. Even with a jump box and jumper cables the electrical system on the car is dead - nothing at all working. It sputtered once as the lights flickered and then went completely off leaving me coasting to a halt on the side of the road.
A real mystery that I hope has a simple solution. |
It turned out to be a loose ground connection on the battery - simple and embarrassing solution to a puzzling problem. And totally my fault for not doing the German Gut-n-Tite test on the connections after removing the battery for another project I was doing on the car. Oh well - lesson learned - keep a 10mm x 13 mm wrench in the car at all times.
Glad to know it ends simple and easy. Thanks.
