![]() | Home > Puma (Tdci) > Injector Washer. |
mifa Member Since: 16 Dec 2022 Location: Denmark Posts: 15 ![]() ![]() |
matchap801
Great write-up – this reminds me that I need to do the same procedure and add new injectors to that equation, which is why it's only in the planning mode! There are several other treats here on priming a Puma Defender – you might need a small DIY tool in your LR unique toolbox for priming. I made my own from bits and bobs, and it works brilliantly. It's now part of the "designated LR special tools," like a steel bar for supporting the drive flange when changing the seals and stuff like that! |
matchap801 Member Since: 05 Aug 2021 Location: Somerset Posts: 120 ![]() ![]() ![]() |
Thanks mifa.
I do enjoy making my own tools from the bits I can. I studied the bleeding tool in advance. But funds and time restricted the options I had. And yes I have a growing set of home built special tools, and spare parts too. Garage is getting full again...... 2009 Defender 90 CSW 2.4 TDCI. Ex Army Mechanic still living the dream. |
mwestcrew Member Since: 09 Dec 2019 Location: South Warwickshire Posts: 287 ![]() ![]() ![]() |
Did my injector seals only a couple of weeks ago and the engine started with no priming after about 5 seconds of cranking. 2011 130 Utility Body
2005 110 Van |
Wow, lucky. I took a lot of the pipes and HP rail off so guess that was the issue. Massive improvement once done though!! 2009 Defender 90 CSW 2.4 TDCI.
