![]() | Home > Modifications & Maintenance (L663) > 90 Hardtop Bulkhead |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1236 ![]() ![]() ![]() |
The grille cannot be removed in a conventional sense.
Ie.. you cannot dissemble it. The grille is bonded into the bulkhead. For sure you could cut the grille section out and replace with Perspex but would be a messy job. I considered this but after due consideration decided to live with the grille Barely notice it now Clemmo ![]() Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadster……..........Vermillion 17k miles Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun |
Mr Fox Member Since: 10 Sep 2011 Location: green & pleasant land Posts: 1038 ![]() ![]() ![]() |
Is there a reason why? I just ask because the bulkhead doesn't touch the roof, so if your reasoning is to 'seal' the back, replacing the mesh won't help. I'm with Clemmo, I don't notice it and even when I chose to not use the Clear View rear mirror, it doesn't bother me. |
NEDXT Member Since: 27 Jan 2022 Location: Sussex Posts: 26 ![]() ![]() |
Thank you both for replying
I was looking at this video hence why I thought it could be removed. I just would like to 'tidy' the bulkhead visually. This is a pic of how my ID Buzz van looks (I had it lined and carpeted in the rear) ![]() Click image to enlarge |
Looks like the trim pieces are held in place by the grill itself; therefore, by removing the grill, they would have nothing to attach to.
I would assume that if you wanted to go the route you do, you could get a company that specialised in acrylic to cut a piece to the right dimension, using the mesh piece as a guide. They could cut the holes in the right places to re-attach it with the screws to the bulkhead and also, if they cut the slots for the trim, you could re click those into place. Custom plastic isn’t cheap but once the jig is made, you could get a few cut and perhaps sell the spares on eBay, etc, and get some of the cost of the setup back. Of course you could also try making one yourself using a Dremel or similar cutting tool! Last edited by Mr Fox on 21st Feb 2024 11:14pm. Edited 1 time in total |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3026 ![]() ![]() |
The grille is useful as it allows some heat into the rear compartment, which is useful in very cold weather.
Biscuits Member Since: 27 Mar 2023 Location: Kent Posts: 71 ![]() ![]() ![]() |
Off Topic:
Has anyone removed the rear window covers? Are the windows solid, or smoked glass ? 2001 90 TD5 Soft Top - Epsom Green 2024 90 D300 HSE X-Dyn HT - Santorini Black |
https://www.defender2.net/forum/topic83156.html
Try this thread, appears they can be changed / swapped out |
Ah, perfect, thanks 2001 90 TD5 Soft Top - Epsom Green
