![]() | Home > Puma (Tdci) > Tub seats in Puma DCPU? |
ScarboroughSeadog Member Since: 21 Jul 2022 Location: Scarborough Posts: 110 ![]() ![]() ![]() |
Anyone done it? I appreciate will not be legal to use on the highway, but would be useful for shoot days etc and farm transport off the highway.
Do standard side facing older defender/series bench seats fit the irritating Puma dog leg bench sides? Suspect not, but suspect there isn’t a seat made to do so either. Would it be an MOT fail if fitted, or only an offence to use on the highway? Thanks |
Thanks- yes, tricky. Would only work with bench. Might just tell the lads they’ll have to sit on a coat….easier!
Just FYI I did extensive research when retro fitting bench seats to my series lightweight tub. Lawful to retro fit these to the tub so long as insurance informed. Not lawful to retro fit side facing seats with belts unless these (the belts) were an original fitment. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17686 ![]() ![]() ![]() |
And therein lies your problem.
Prob didn’t make it clear- lawful to retro fit side benches (to the Lightweight), so long as seat belts are not fitted.
Yes, but they must be fitted in the Puma and there are no approved belts for side facing seats.
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6162 ![]() ![]() ![]() |
Subaru Brumby/BRAT rear seats anyone?
Yes- a no no all round I think for the Puma DCPU- I knew it really. |
MatLandy Member Since: 11 Sep 2020 Location: Paris Posts: 196 ![]() ![]() ![]() |
Gwyn Lewis makes a bracket to fit discovery 1 jump seats to the Puma stepped wheel arches: https://gwynlewis4x4.co.uk/product/diy-dickie-seat-base/
May be a solution ? I have been contemplating going that route since removing the 2 foldable forward facing seats of my Puma CSW (around 60kg less weight and much more load space). I have sourced all required parts, but never got around fitting yet. These are not intended to be used on the road, and temporarily removed every second year for the french MOT so no questions asked. /Mat |
