Home > My Defender > Mud Centre Console + Carling Switches + Double DIN |
Craig772 Member Since: 23 May 2022 Location: Cannock, Staffordshire Posts: 73 |
Getting there with my MUD centre console. I'd previously done a temporary installation but had it out over January to progress it further.
Relocated the rear fog switch, rear washer wiper and hazards. Installed the rear worklight and front floodlight switches. I currently have a fog light switch installed but will likely swap the cover for DRL. I haven't yet moved the rear demist switch as it doesn't work anyway. I'll do that after I replace the rear door and will likely place it where the rectangular USB outlet is and install a second circular USB outlet. I haven't bothered with the headlamp levellers. They don't work, or at least appear not to from inside the cab and I don't think they add much value. Certainly with LED headlamps I don't feel the need to adjust them and haven't been flashed by oncoming vehicles when towing. The two red covers are for toggle switches that prevent the light bar (when installed) being accidently switched on, same for the rear worklights (which are installed). You have to have the toggle switch on and the relevant other switch. It might get too faffy but for now I like the James Bond approach. There's a loom that runs into the battery area carrying an ignition line and lines for relay triggers (with spares). Next job is to install the accessory fusebox and relays into the battery area. Click image to enlarge Click image to enlarge https://www.instagram.com/roxi_defender90/ |
12th Feb 2024 11:10am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10801 |
Good bit of work going on there 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
12th Feb 2024 8:45pm |
