![]() | Home > In Car Electronics > Another dim/dip question |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 787 ![]() ![]() ![]() |
I just unplugged the resistor to disable mine
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5813 ![]() ![]() |
One or the other. Don’t need to do both. |
nick.bw Member Since: 26 Oct 2020 Location: Essex Posts: 76 ![]() ![]() ![]() |
Ohh what does this achieve, brighter dipped beam?
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17612 ![]() ![]() ![]() |
It prevents the dip beam headlights being illuminated at reduced power when the sidelights alone are on, it makes no difference at all to dip and main beams.
Dim dip causes significant problems if you replace your halogen headlights with LED units, since these don't work properly on reduced voltages. It also shortens very considerably the life expectancy of H4 bulbs since halogen bulbs do not function properly when run "cold". It was a rather half-witted and short-lived legal requirement in the UK only, which the EC almost immediately ruled to be an illegal requirement. It then became optional since it couldn't be mandated, however most British manufacturers continued (annoyingly) to fit dim-dip systems. |
This is what a dim dip resistor looks like
![]() ![]() Click image to enlarge |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1148 ![]() ![]() ![]() |
There was a time that every country had their own lighting requirements which could be illegal in another. In Scandinavia you had to have headlights on and I recall in Holland there was a point it was illegal to have your headlights on during the day (?). in the 70-80s we had a imported Swedish Volvo which had dedicated bright corner lights (25w) and everyone used to flash their lights at us - yeay yeay.
Then there were people saying it would be bad for the battery to have your headlights on permanently. I suppose the half headlight (dimmed dipped lights) was a solution to that? Now the complaint is that modern (LED) lights are too bright and cause blinding, which I do agree with. Its a whole dog and pony show now with lights going and off around corners. In the USA for a long time ONLY the sealed round and later rectangular headlights were allowed (clearly a monopoly from the manufacturers). At least this resulted in cheap lights, such as fitted on our defenders compared to some of the modern lighting fitted... |
