Updates and Advice
Hi all, Its been a while since I've done much so...
Driver side (always seems to be!) wiper seized about 18 months ago so dash out, two new spindles, rods, all greased up and working great. Not nearly the job I was expecting so done in several hours. Thought I would leave the dash out incase there was anything to do that this would make it easier... and here we still are driving around with no dash. The MOT man was a bit taken aback but all the switches were connected so it passed with no advisories:). No one is aloud in the passenger seat.
So question, what can I do before putting the dash back... (all dash lights changed and everything sealed already) Thought about bulkhead sound proofing but really does not seem anywhere to attack, I have seen videos of people dynamatting the air ducting and heater but not sure that makes a difference. Going to upgrade speakers but that can really be done anytime.
Next, Had the usual driver door split to the left of the lock peg ages ago, bought a replacement section but ended up just bolting it over the original, well that then split as well.
Bought another replacement section and had the old cut out and new welded in, great job. Additionally they put a bracket on the inner panel to the door which has stopped all the flex so should not happen again. Will sound proof the door before putting back together.
Replaced all the door hinges and bolts as well as windscreen blocks, looks much better.
New wheels, 18", I know some don't like them but I love them and that's what counts
Only got 4 so new spare wheel cover to hide the Boost, love it.
New seats in, from an Evoque, electrics connected up so all working (ish) added height took some getting used too with the clutch but all good now.
So the (ish) is I connected the passenger one to the original heated seat switch wire, turned on, seat heated up... ALOT, and then went off. Presume it burnt out on the pad. I had presumed as the original seats were fused this would be fine but obviously not. Any pointers on what to do before I blow the drivers one would be appreciated.
To do:
Need to tidy the rear crossmember AGAIN, where does the paint go???
Replace the sidesteps AGAIN, thinking of splashing out on the recently released stainless XS type or just keep replacing with the cheap ones every three years for the next 18 years, costs about the same.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
