Home > Puma (Tdci) > Steering box?
110 Iain
United Kingdom 2008 Defender 110 Puma 2.4 USW Chawton White
Steering box?
Moving on to my next issue I have heavy steering as been like this since I have owned. About 2 years how can I tell if I have duff box swivels brakes track rods damper all changed this year but still stiff steering virtually no return to centre box's looks fairly new no leaks fluid moving in resevoir. Any advice appreciated again! thanks to all who keep advising me Iain Endeavour To Persevere
Post #948346 6th Apr 2022 3:46pm
htb2
Wales
Suspension lift? without castor correction.
Post #948347 6th Apr 2022 3:52pm
Tommybahama32
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
Have you checkecked the universal joints on the coupling shaft between the column and the steering box?these joints can seize, worth checking. Very Happy
Post #948362 6th Apr 2022 4:48pm
110 Iain
Ujs look OK have soaked in oil off and on standard height just not sure about fitting new box when one fitted looks mint no leaks also are recon boxes any good new box £900 Endeavour To Persevere
Post #948375 6th Apr 2022 5:37pm
Tommybahama32
Have you actually taken the shaft with the uj's off and checked if they are stiff or notchy?, also you could try disconnecting the balljoint at the drop arm at the steering box see how that feels, also disconnect ball joints at both stub axles and feel if there's any tightness there. I had a bad experience with recon steering boxes so ended up buying a new Adwast box. But I'm sure there are some good reconditioners out there. good luck hope you get it sorted Thumbs Up
Post #948385 6th Apr 2022 6:23pm
110 Iain
I have a compleat new shaft will fit that first and see how it goes I am now wondering if I have set the swivles up to tight now doubting my own work will perhaps re check shims on pins thanks for help Endeavour To Persevere
Post #948388 6th Apr 2022 6:29pm
sykes705
United Kingdom 2005 Defender 110 Td5 XS CSW Epsom Green
Well what the outcome? I have same issue
Post #1023418 3rd Feb 2024 11:13am
sykes705
Well for reference my problem was a build up of mud in the steering uj
Quick blast with wd40 and then some oil sorted it out.
Post #1023590 4th Feb 2024 8:59pm
110 Iain
Replaced just about everything apart from steering box but still stiff have just learned to live with it wife hates it
Need to try get a drive in another defender to see if mine is bad or not Endeavour To Persevere
Post #1023693 5th Feb 2024 6:41pm
