Home > Td5 > Oil leak suggestions |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2229 |
Losing the will to live with this Defender, have replaced the engine due to melted piston, new engine runs okay but hideous oil leak. Changed alternator as the vacuum pump was leaking badly. However looked this morning and i still have a substantial oil leak on the front right corner of the engine.
There isnt much there to leak really. Fairly sure its not the vac pump feed or drain. Only other thought is the timing chain tensioner. Its definetly the front corner, dripping off the bottom of the alternator mounting. Any suggestions at all please? Cheers 02' 110 TD5 Double Cab Rebuild Thread |
3rd Feb 2024 10:03am |
1NRO Member Since: 22 Feb 2015 Location: cumbria Posts: 72 |
Bolt for the tensioner maybe?
3rd Feb 2024 6:32pm |
Got chance to investigate again yesterday afternoon, top of the new alternator and vac pump is nice and clean, no signs of leakage around the tensioner or oil feed. However, the blanking plug on the front of the cam sprocket was hanging out
Have swapped it out for another one I have which looked to have a better o-ring. Hopefully that will solve the issue now. It was certainly not an issue when i changed the alternator the other weekend. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
5th Feb 2024 8:47am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5846 |
I think the front cam seal never seals. They always seem to leak even with sealant. 1999 Defender TD5 110
5th Feb 2024 9:28am |
