Home > Technical > Headlights not working
Karlchadw
Hi All
I have a td5 90 2005, So come to use the car and the dipped beam doesn't work, only sidelights and full beam. Replaced the stalk and that has not cured the problem. Swapped the yellow relay around in the fuse box behind the gear stick and that hasn't worked. Anything else I should be looking at???
Thanks
Post #1011787 19th Oct 2023 1:58pm
geobloke
How odd. Check connections behind the headlight. Check voltage when dipped beam is on, is it the bulb/lamp or the wiring? It shouldn't be both the dipped beam fuses, but check them too.
I suspect it is an earthing problem though, so go around and check all the vehicle earths are in good order.
Post #1011792 19th Oct 2023 2:14pm
Inguz
Have you tried changing the bulbs? I had a similar issue recently and it turns out that both bulbs need to be working or none will work. Mind you the bulbs looked fine, but I just chanced putting in two new ones, and viola
Post #1012434 24th Oct 2023 11:25am
Re: Headlights not working
Karlchadw wrote:
Hi All
Thanks
When you say 'replaced the stalk', do you mean indicator one? If so, take a look at the 'switch' stalk, which can also fail. Darren
Post #1012439 24th Oct 2023 11:44am
geobloke
Post #1012466 24th Oct 2023 2:58pm
DICKO1995
United Kingdom 2007 Defender 90 Puma 2.4 HT Tamar Blue
Wipac headlights no main beam
Hi,
First post on here. Go easy.
I’m having a nightmare with fitting Wipac led headlights, should be plug and play but not that simple (for me anyway)
So my problem is that I have power to the headlights but only seem to have a low beam. With one push forward on the stalk the low beam comes on, when pressing the stalk forward again nothing changes, as if the main driving beam is not working. The full beam/flash is working and so are the DRL’s which are wired to the led sidelights.
I’ll attach a photo of the Wipac fitting instructions.
The main beam does work when the brown wire (main beam) and the green wire (dipped) are touching each other with the earth plugged into the connector. So i know that the main beam does actually work but once the wires are put into the connector and connected to the car I only have a small beam of light for both clicks of the stalk.
Any help on this would be great. Could be me being stupid Laughing
Post #1023297 2nd Feb 2024 10:13am
