![]() | Home > Technical > 10AS Repair: Technozen ceased business?? |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2134 ![]() ![]() |
Worth giving remotekey a call https://www.remotekey.co.uk/category/land-rover/defender/ they undertake 10AS repairs.
Also, you can buy a used 10AS on line, just make sure it’s the same model you have, then reprogram. However you will need a Nanocom or equivalent to do the programming. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2448 ![]() ![]() ![]() |
www.m1n1.de Puma 110" SW
robk Member Since: 30 Dec 2015 Location: Zeist Posts: 12 ![]() ![]() ![]() |
Hi forum
A brief update. I contacted m1n1.de, Ralf. Very pleasant to deal with, quick turnaround of the repaired unit. Can highy recommend him! Especially for EU customers, as you will not have any import and tax issues when dealing with UK companies when you're living in the EU. KR Rob |
He does know his stuff, he produced a great article on the brownout issue with the Later ALM CHxxxx units.
