Home > Puma (Tdci) > Clean oilchange
hornet
Clean oilchange
Since I have been doing my own oil changes for some time and unfortunately do not have a platform, I have installed a drain valve-system that allows clean oil changes. Without any mess (except for the filter)
I tested it for the second time now since installing it and i really appreciate it and thought it would be an interesting information on that forum.
I do not want to advertise in any way, there are also competitive products.
http://www.stahlbus.com/info/en/products/oil-drain-valves
Edit: Our plug is M 14x1,5
Post #1023019 30th Jan 2024 2:31pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Yeah I use a different brand but handy things these
Post #1023027 30th Jan 2024 5:00pm
Ianh
Post #1023031 30th Jan 2024 5:30pm
Bluest
I’ve got the Femco one. Very handy, but quite slow to drain. 2007 110 TDCi Station Wagon XS
Post #1023040 30th Jan 2024 6:57pm
kmac
Ianh wrote:
You probably have a femco one https://www.defender2.net/forum/topic52187.html?highlight=femco
Yes I have a femco. When I got it there was an option of two sizes and I think I got the larger gauge
Post #1023057 30th Jan 2024 9:31pm
swt
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
The stahlbus is great - I wouldn't be without it. I still manage to make a mess with the filter mind, usually managing to drop it into the pan of dirty oil for good measure.
The other place that would benefit from more controlled draining on a Puma engine is the coolant pipe into the oil filter housing. You whip that off and, unlike the gentle flow from the fuel cooler pipes, a torrent of coolant goes everywhere.
Post #1023065 30th Jan 2024 11:47pm
Ianh
Been there as well when draining the coolant on my 2.2 which does not have a fuel cooler to drain from.
When you take the hose off the oil cooler there is no room for a container and a torrent of coolant goes all over chassis. It took me about 20 minutes hosing the whole chassis and surrounding areas clean. Sad
Post #1023067 31st Jan 2024 1:47am
geobloke
Just be very careful not to over torque these drain plugs, the metal is very thin and they can shear. I used to have the Femco one and it was fabulous for many many years, but sheared in half when undoing the dust cap. Make sure you keep the threads greased is my advice Thumbs Up
Post #1023100 31st Jan 2024 1:12pm
landy andy
I don’t use a drain pan when using the Quick drain fitting. I put hose straight into an old 5ltr container and drain it direct into that. When nearly full slacken pipe, stops the flow, swap to another container and go again till empty.
Post #1023109 31st Jan 2024 2:31pm
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
Looks like a great little gadget. I find when draining the oil it hits the ARB and goes everywhere.
Definitely on the shopping list, the Defender is due an oil change soon.
Post #1023127 31st Jan 2024 5:02pm
swt
Such good advice. I went slightly over the recommended torque the first time I fitted one, and it sheared straight off. The remaining portion of the valve was relatively easily recovered with a fat bolt extractor, but a brief moment of bad language was occasioned.
Post #1023160 31st Jan 2024 9:30pm
swt
This is sage advice. I must keep some 5L empties. Next time I drop the filter housing, it will be into an empty pan.
This will also cut out that other stage of the operation, where I decant the pan into 5L bottles and either knock them over, cause one to overflow, or get the drain nozzle of the pan stuck in the neck of the bottle.
Post #1023163 31st Jan 2024 9:38pm
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
I also use a Stahlbus drain valve and it really is a great bit of kit, easy to use and no mess.
Post #1023194 1st Feb 2024 10:58am
steveww
In the UK you have to order through Demon Tweeks.
Just ordered one and lots of oil from Opie.
Post #1023205 1st Feb 2024 11:44am
