Home > Wheels & Tyres (L663) > Correct Tyre Pressure - 110 |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20576 |
Probably done for transport so they are at least, at or above recommended pressures when collected by the customer.
Just put them to the pressure recommended, you will likely find it in the owner manual somewhere. I highly doubt it is anything to worry about. Rear pressure sometimes is increased, if towing heavy is required. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
28th Jan 2024 7:46pm |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1225 |
Legally manufacturers have to display a label with recommended tyre pressures.
These days with different wheel/tyre combos and the laden/unladen spec the labels are often quite confusing. On my Defender the label is on the drivers door. Inconveniently very low on the door so I have to grovel on my knees to remind myself. Clemmo Make today a little better than yesterday but not so good as tomorrow.... Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadster……..........Vermillion 17k miles Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun |
28th Jan 2024 8:47pm |
martinf Member Since: 30 Nov 2020 Location: Sussex Posts: 103 |
I follow the recommendations on the screen with a light load setting and it seems fine
29th Jan 2024 9:14am |
tonyp Member Since: 03 Feb 2023 Location: Northern Ireland Posts: 83 |
Thanks Clemmo, Followed your advice, mine is also very low on the drivers door - I looked everywhere else around the vehicle that was obvious and based on previous cars owned. Tony |
29th Jan 2024 10:20am |
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 164 |
Just in case people dont understand, tyre pressures when warm will be higher.
The pressures quoted on the label and on the dashboard are for cold tyres. However, even if the tyres were warm , i would only expect an increase of 3-4 PSI. So i think you have grounds for complaint.. |
29th Jan 2024 8:31pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2766 |
Not to get too geeky here but I think the ‘recommended’ pressures on the dash change with temperature too. For mine they change between around 36 and 41 for the rears for example depending whether I’m stationary or driving at speed. Clever stuff!
Would just match what the computer wants yes unless you are doing something specific Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
29th Jan 2024 9:09pm |
If you check it and change it when cold, then you will know it’s a reliable benchmark as they should be adjusted when cold anyway. KEEP CALM AND Drill ON
29th Jan 2024 9:10pm |
