Home > Td5 > TD5 Starting problem |
Air in the system sounds about right to me too.
1) Fuel filter housing corrosion, especially around the join between the outlets and main housing. 2) Fuel Pressure regulator failure - might see diesel dripping down the block. 3) Injector seals have failed and need replacing. Plus odd ball possibility; 4) Crank position sensor or wiring loom. I doubt it is this one though... |
22nd Jan 2024 10:58am |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 903 |
If there is air in the system, you should be able to hear gurgling noises when the fuel pump primes having been left overnight. Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
22nd Jan 2024 1:34pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5788 |
Try running the fuel prime before a start and listen to the noise then try.
22nd Jan 2024 2:38pm |
turnah Member Since: 30 Sep 2018 Location: Lancashire Posts: 40 |
I've recently had similar and fixed by reseating the yellow relays and cleaning any oil from the red plug. Not sure which the culprit was though
24th Jan 2024 3:56pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20576 |
Would similar symptoms occur with a heavily soiled fuel filter?
I’d have thought a well used fuel filter would begin to clog, cause the fuel pump more work to pressurise and especially starting up. Tending to lead towards fuel starvation / restriction. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
24th Jan 2024 4:10pm |
Alan Member Since: 10 Oct 2013 Location: United Kingdom Posts: 4 |
I am having a similar issue.
TD5 2004, always started perfectly, started to struggle to start , it always fired quickly but felt like it was running on 2 cylinders for about 3 or 4 seconds, once running it was perfect and would start ok all day until next morning. took to a well known 4 x 4 specialist who changed injector loom, injector seals, fuel filter and housing, air flow meter, got it back and its worse, took to another specialist who changed glow plugs and fuel filter housing and apparently cured it, picked it up yesterday but went to start it this morning and its exactly the same, very frustrating nobody seems to know, I am puzzled, could it be fuel regulator ? |
27th Jan 2024 8:23pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 636 |
Did they measured fuel pressure? It could be bad in tank fuel pump, or just some leako somewhere. Try fuel purge cycle before starting.
And from my experience, TD5 needs run for at least 30 km or 1 hour after any fuel system work, to finally purge all air from fuel system. Just short indle is not enough and car needs another purge next day. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
29th Jan 2024 7:08am |
Thanks Tom. I will give it a try
29th Jan 2024 8:08am |
