Home > Td5 > Oil change - plug help
DefenderSTW
United Kingdom 1999 Defender 90 Td5 SW Firenze Red
Afternoon guys
I’m looking to do my first oil change on the defender td5 but stopped at the first hurdle. Everywhere I look the specifications for the sump plug are 16.5mm but where I think mine is it’s a lot bigger at 18.5mm.
Is this the right plug and I’m guessing the replacement 16.5mm plug wil not be a suitable replacement. Bit strange. Seen a few videos online but they all look different.
Pics attached if someone would comment?thanks!
Post #1022469 25th Jan 2024 1:44pm
htb2
Wales
Mine takes a 17mm socket, they are easily stripped. So it may have been stripped before and replaced by retapping a size up and an oversize plug.
Post #1022470 25th Jan 2024 2:45pm
DefenderSTW
Gotcha, thanks. Thought that maybe the case. Some videos I have seen show the sump plug on the side rather then on the bottom which is where I was a bit confused. - I may just take it to my nearest garage and let them deal with it, especially as I don't have any ramps ect, its a bit of a faff.
Post #1022474 25th Jan 2024 3:27pm
htb2
Wales
Where in S. Wales as I am moving near Llandovery?
Post #1022475 25th Jan 2024 3:32pm
DefenderSTW
PM'd you. I am local to Llandovery!
Post #1022478 25th Jan 2024 4:26pm
geobloke
Your sump plug looks original to me. Get the engine nice a warm before trying to undo it, much easier to get it moving.
When you get the sump plug out you might want to think about a magnetic version as a replacement https://www.lrparts.net/lrc1512-super-magn...00040.html
Post #1022479 25th Jan 2024 4:34pm
DefenderSTW
Nice plug thanks! I will certainly invest as that looks like a lovely peice of kit.
I am cautious because of the difference in size to everywhere else I read. The sump plug replacement is Britpart TRL100040
https://www.lrdirect.com/trl100040-sump-plug-td5
I don't have .5mm sockets so my 17mm fits over the replacement plug I have, but in comparison I have to select a 19mm to fit around the plug already in the car.
Once I solve the plug issue, yes - good tip! I'll go around the block and give it 30 mins to cool down thanks!
Post #1022481 25th Jan 2024 4:45pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
And don’t forget to replace the crush washer Whistle Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #1022482 25th Jan 2024 4:47pm
geobloke
You don't need a washer, just use a 3 foot breaker bar and really torque it up tight Rolling with laughter Rolling with laughter Whistle Whistle
[Joking obviously]
Post #1022484 25th Jan 2024 4:48pm
Screbble
And when you’ve got it removed - https://www.difflock.com/drain-plug-m14-x-1-5-t11-5
Post #1022504 25th Jan 2024 8:42pm
