Home > Technical > Dual battery volt gauge available in the UK |
Hey forumites.
I am after a 52mm dual battery volt gauge for my new Mud Pod. Ideally what I would like is a black analogue gauge but I would consider a stacked bar style. Prefer analogue but a digital gauge would do. Does anyone know of such a thing available in the UK? I know you can get them in Australia from the likes of SAAS or Redarc or Topo. Click image to enlarge Failing this I will go to Plan B which is a single sweep gauge and a changeover switch. The reason for not fitting a battery monitor like the Victron BMV-712 is that they have a gauge bezel diameter of 63mm and the Mud Pod has a 60mm space before the lip of the pod. Which is a bit irritating. Click image to enlarge |
24th Jan 2024 9:27am |
Just an update.
The Redarc gauge is not available in the UK or Europe as it does not meet product standards... |
24th Jan 2024 10:08am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5883 |
maybe a bit pricey? https://www.vwjim.co.uk/ourshop/prod_35599...Gauge.html 1999 Defender TD5 110
24th Jan 2024 10:16am |
Thanks John. I saw that as well. Lovely gauge I am just not sure that I could face having a VW component in Miffy
24th Jan 2024 10:17am |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 503 |
Another Australian offering -
Dual Voltmeter With Digital Voltmeter Reading 52MM LCD 3 IN ONE GAUGE Click image to enlarge Also on eBay - https://www.ebay.co.uk/itm/172411425927 . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
24th Jan 2024 5:19pm |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1432 |
I thought CE meant Chinese Engineering Eiger Grey MY23 D250 SE with bits. Known as Noddy.
24th Jan 2024 6:01pm |
It is an utterly utterly ludicrous situation
24th Jan 2024 6:04pm |
Another option from our friends -
https://www.aliexpress.com/item/32912650055.html Click image to enlarge . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
24th Jan 2024 6:13pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6120 |
That SAAS one is neat.
24th Jan 2024 6:43pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1662 |
Chinese Export I thought |
25th Jan 2024 12:09am |
Well the hunt continues but there might be light not he horizon...
25th Jan 2024 8:46am |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 575 |
You use a regular single volt meter and add in your own switching to select which battery is read. A SPDT switch would do it.
26th Jan 2024 12:26pm |
That is Plan-B
26th Jan 2024 12:27pm |
