![]() | Home > Maintenance & Modifications > Rear view mirror removal |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
just turn anti clockwise and it will pop out easy ,
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Thanks KOTS but would it pop back on as easily afterwards? What's left once it's off - an unweildy bare clip?
goes back easy , leaves a hole the mirror has a clip on it , you will see when you pop it off
You're a legend. Many thanks
Glad your happy, forums are great places
Landyrob Member Since: 07 Jul 2011 Location: Switzerland Posts: 93 ![]() ![]() ![]() |
yeah you can pop in and out now worries, have mine out too...
chopdogs Member Since: 10 Mar 2010 Location: Wiltshire Posts: 108 ![]() ![]() ![]() |
Mine was vibrating madly - so took it off as per your advice........
How do I get it back in again? ![]() ![]() Thanks! |
daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246 ![]() ![]() ![]() |
push until it clicks 2001 TD5 110 DCPU in Bonatti Grey
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
speaking of which, can one get one of those fancy auto-dimming mirrors that will fit in the Defender? --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
MuddyMarky Member Since: 01 Feb 2010 Location: Oxfordshire Posts: 548 ![]() ![]() ![]() |
Isn't it frowned upon/illegal to not have an interior rear view mirror if you have a rear window in your vehicle? I'm sure it's an MOT failure at least. Mark
2011 110 XS DC Stornoway Grey |
I think the requirement is for at least two mirrors - so one inside and one out, or two outside. If you think about it, there are plenty of vehicles in which an internal rear view mirror wouldn't serve any purpose. Darren
Done it. The top catch wasn't retracting - had to give it a shove with a screwdriver to free it up
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17698 ![]() ![]() ![]() |
The law nowadays requires a minimum of two rear view mirrors, one of which must be external and on the offside of the vehicle.
It doesn't matter where the other is, so it can be external on the left or internal. There is no maximum, so provided that forward visibility isn't compromised, you could go for the "mod moped" look if you wanted. I am not actually aware of any reason why your two mirrors couldn't both be external and on the offside. |
45� more or less Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
