![]() | Home > Td5 > Defender headlights not working |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 916 ![]() ![]() ![]() |
Normally it is the switches burning out.
Have you checked the fuses? Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
Benbencarter5 Member Since: 21 Jan 2024 Location: York Posts: 3 ![]() ![]() ![]() |
Yes I’ve checked all the fuses and replaced both switches.
Hmmm, odd.
Are you on LED headlights or halogen? Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
I was on halogen and then I changed to leds but had the same problem with both.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17682 ![]() ![]() ![]() |
I'm not especially familiar with the TD5 wiring but assuming that it is generally similar to the early Puma, there is likely to be an ignition-energised relay which prevents the headlights from being on without the ignition. If this has failed, it would produce the symptoms you describe.
Ok. Begin with the simple things. Get yourself a multimeter to test that 12v is getting to the switches and headlights. It could be a dodgy connection somewhere, corroded fuse connection or something.
This is your best way forward. ![]() |
This is the wiring diagram for the TD5 https://www.lrworkshop.com/wiring-diagram/...e-tail/td5
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5849 ![]() ![]() |
Short out / bridge the dim dip relay.
Also make sure the wiring connections and the new light switch are good. New parts aren’t always good parts. |
nosuchthing Member Since: 01 Sep 2022 Location: Woldingham Posts: 22 ![]() ![]() ![]() |
I just want to add to the knowledge base and probability of the various solutions for 'no dipped beam'.
My TD5 recently lost its dipped beam headlights - but sidelights and full beam were still working. A number of suggestions have been made in various posts on the forum - i.e. light switch itself, stalk switch on steering column, and dim/dip relay. The dim/dip relay crops up in many suggestions and is very easy to access (it's behind the speedo panel on the dash - just four screws to take out - no need to disconnect any connectors or speedo cable) - and in my case the relay was in fact the problem. The pink one with reference YWC 10050. A five minute job and the headlights are fine again. Hope this helps someone. |
