Home > Puma (Tdci) > Carpeting in the front
Yorkshire lad
United Kingdom 2015 Defender 90 Puma 2.2 HT Indus Silver
Just wondering if anyone has taken the factory rubber mats out and soundproofed then put carpets in. And your opinion on if it's worth doing for reducing sound/keeping a bit more heat in and actually looking better.?🤔
Post #1022065 21st Jan 2024 6:02pm
LR90XS2011
mine came with carpets, I took them out soundproofed, put them back and have rubber mats on top, the sound proofing was well worth it. DEFENDER 90 TDCI XS,
Post #1022068 21st Jan 2024 6:21pm
Rashers
My 110 which is a 2014 came without carpet, but had the rubber interior.
I was pretty fed up with this when I got it, but in hindsight, the rubber interior has been so much more practical to live with.
Post #1022073 21st Jan 2024 6:34pm
Glen-I
Personal preference, but I have rubber flooring/mats in my 2014 110XS and carpet in my 110 TD5.
For me, it's rubber all the way.
Rubber is easy to clean and more importantly the carpets seem to soak up water (not good)
Post #1022082 21st Jan 2024 7:35pm
I put Dynamat down, then refitted the rubber matting.
It was well worth doing, I prefer the rubber for reasons others have stated.
My rubber matting could do with replacing, my only annoyance is that the rubber matting is very expensive, but does have a very long life so I suppose counters that.
It’s a pity it isn’t a bit more hard wearing on the edges and corners.
It improves sound proofing, merely the rubber matting it’s self on top of the soundproofing. Chillin In The Backwoods🇬🇧🇺🇸
Post #1022088 21st Jan 2024 8:04pm
MK
I had to remove the very whole thing from the bulkhead when trying to bring to life again a drowned 2.2 Puma. So I covered with dynamat style butyl sheets every single panel part in the interior.
At the end it improved a bit the noise but nothing dramatic. Most cars nowadays have noise barriers in not only in the inside, but also outside of the bulkhead. Would I do it again? No.
I think it would work better by adding a noise shield behind the engine. Puma 110" SW
Post #1022144 22nd Jan 2024 10:55am
Hedwig
We found the original vinyl/rubber seatbox covering was getting shabby in ours, so we decided to take it all out 2mm silent coat and then carpets on top. It's certainly tidied things up a bit inside, but ours was looking very worn.
I'd recommend some seatbox corner protectors we find we're always dragging our feet past the corner when getting in and out.
One other thing we did was to get some 6mm closed foam and mass loaded vinyl, this went on the floor underneath the mats and does a reasonable job of quietening things down. We also didn't put in the carpet floor mats and got some rubber ones instead. The seatbox rarely gets wet so being carpet I haven't worried about holding moisture. In the footwells to me it makes sense to keep this rubber to avoid having to worry about holding on to moisture.
Also, one other thing, we got our carpets from exmoor trim, but found that on the sides of the seatbox they were a little short, so whilst I'm still ok with the finished result, I wouldn't necessarily buy those carpets again.
It wasn't night and day in terms of being quieter but it did make some difference.
Post #1022156 22nd Jan 2024 12:18pm
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
yep well worth doing try and get it as far up the bulkhead as you can as most of the engine noise comes through the bulkhead.
Then do the seat box as well, transmission noise and engine noise comes up there
Post #1022172 22nd Jan 2024 2:34pm
Yorkshire lad
Thank you all for your replies I shall get all the bits ordered and get it done thinking of going with the lucari set they look like a nice set. And also get some stainless steel door trims to finish it off nicely.🙂
Post #1022239 22nd Jan 2024 8:52pm
JoolsB
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
I did it, sound deadening all through then carpeted, did the back too - it’s a much nicer place to be.
Post #1022240 22nd Jan 2024 8:53pm
Yorkshire lad
Update on sound proofing and fitting carpet
Just a bit of an update I sound proofed all the front with dodo mating and fitted lucari carpet set. I'm very pleased with the result and it's crazy how much the noise difference is 🤯. Also while doing all this I fitted some bearmach door seals and I'm very impressed with them considering I get them for £40 and genuine are about £200.🫣
Post #1024223 10th Feb 2024 4:25pm
Yorkshire lad
Will upload a few more when I get chance
Post #1024224 10th Feb 2024 4:26pm
Yorkshire lad
Post #1024250 10th Feb 2024 7:30pm
Screbble
That looks very nice indeed.
A good job well done 👍
Post #1024253 10th Feb 2024 8:30pm
Yorkshire lad
Thank you screbble. 🙂
Post #1024372 11th Feb 2024 5:36pm
