Home > Puma (Tdci) > Help needed !!!!!
bunnyman
England 2009 Defender 90 Puma 2.4 HT Galway Green
Help needed !!!!!
HI all just drove down to Exmoor engine management light has been on most of journey but is running fine. Never been on in ten years topped up engine oil and water before journey do I need to get this looked at down here for a week ?????
Post #1021983 21st Jan 2024 9:03am
andy63
You need to get the fault codes read and take it from there👍
Post #1021984 21st Jan 2024 9:08am
bunnyman
Ate there any serious faults or just likely be mass air flow clean?
Tdci 09 plate
Post #1021989 21st Jan 2024 9:44am
BrickBox
Not sure how close these are to you.
https://www.southwestlandrover.co.uk/index.php 2008 2.4 110 Utility Station Wagon XS.
Post #1021990 21st Jan 2024 9:48am
Dinnu
Get an OBD reader with wifi capability and download an app on your phone. You will be able to read the error code, and even reset it to see if the error comes out again.
The OBD reader is worth every penny, and not a lot of pennies will go i to it 😂 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1021994 21st Jan 2024 10:21am
ickle
If its running fine, normal temperature, no nasty noises, oil ok etc etc it may go out after 6 stop start cycles or may need clearing / checking codes.
Don't overly worry, keep an eye on temp and have a good weekend!
Post #1021998 21st Jan 2024 10:42am
landy andy
Check your air filter is dry and ok.
Post #1022016 21st Jan 2024 12:18pm
bunnyman
Hi all have cleaned the mass sensor , I have a code reader at home but didn’t want to go th a garage and pay out if possible
Just to be told it was the sensor . I was more worried that I might cause some major damage if I kept driving it even thou it driving fine
Post #1022022 21st Jan 2024 12:47pm
Daphne
United Kingdom 2015 Defender 110 Puma 2.2 HCPU Fuji White
It’ll go into limp mode before any damage is done.
Post #1022126 22nd Jan 2024 8:22am
bunnyman
Thank you all for your replys
Post #1022128 22nd Jan 2024 8:41am
