![]() | Home > Maintenance & Modifications > 200tdi > Td5 conversion - am I missing anything? |
Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 226 ![]() ![]() ![]() |
Just got the Td5 in my 110 fired up after doing this conversion.
Overall I've not hit too many snags, a few of things to be aware of: Defender and Discovery power steering pumps are almost identical apart from the thread of the high pressure output to the pump. You'll likely need to buy a defender pump or fabricate a pipe with the correct end (I was trying to save money so cut the defender union off and welded the end off the discovery pipe in its place). Td5 runs very happily on a Bosch 044 equivalent from Sytec. I'm running a pre-filter, the pump, a fuel filter, and a non return valve to keep everything nice and clean. This does away with the fairly complex Td5 pipework and the porous filter heads, means you can use your current tank, and cost about £150 including all fittings etc. A replacement pump is about £60. For information, the Td5 fuel pipes are 6mm inner diameter. 8mm hose will push onto the barb on the fuel pressure regulator and fuel cooler for your supply and return. Or you can use 8mm to 6mm reducers to use the factory fuel pipe connectors. Defender 15p coolant flow is pretty complicated and from what I could find (or not find) poorly documented. I've eventually ended up with the correct pipe work! Creating a working loom from the discovery harness isn't too bad of a job. But I'd probably buy an off the shelf harness if I was going to do this conversion again just to save some time. Buy some suitable connectors to replace the bullet connector block for the engine harness if you're going to mix old and new looms. Hope this is helpful! 1990 Defender 110 200TDI Camper - now converted to Td5 power |
Woody3 Member Since: 13 Jan 2010 Location: Derbyshire Posts: 415 ![]() ![]() ![]() |
Sorry I've not responded sooner to this thread - my Defender project was put on the back burner for a while unfortunately.
Hazza, that's very useful information, thank you. It'll definitely come in handy! JR - that's good to know regarding the wiring looms, again thank you. I am yet to source a decent td5 engine, so at this stage I am keeping the 200tdi and cracking on with my bodywork restoration, but hopefully I'll find one in the not too distant future! Thanks again for everyone's input! I'll update as and when I start the conversion! |
Jorge-Peru Member Since: 18 Jan 2024 Location: Lima, Peru Posts: 2 ![]() ![]() |
Hi diesel_jim, I'm new here, from Peru, We have the problem that We can't import a Td5 or Td4 because of fabrication years here, I read you built 3 Td5's and wanted to contact you, if you read this message, here is my email jguerrerob@gmail.com |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 508 ![]() ![]() |
Discovery 300 x member doesn't fit without modification Defender 300 X member is deeper for deeper Defender chassis rails. |
