![]() | Home > Maintenance & Modifications > Cup holders |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20726 ![]() ![]() |
I know this is a subject quite often brought up, but, cup holders in limited space is an issue in Defenders.
Whilst mounting points and methods are plentiful does anyone know if a ball mount Ram mounting fits the back of cup holders like these: https://www.mobilestoragesystems.net/produ...eq=uniform Or does this type of holder ONLY suit mounting on a flat surface? Is there a Ram ball mount base that would fit the back mounting of these? I know there is the self levelling ones as well, that are significantly more expensive. I’m tending to think of the grab handle, with the ram claw which I already have. Rather than ball mounts static on the dash so is totally swiftly removable. I’d have thought with the fold up holders, that the base is ideal to place a cup on when parked up, and the upper retaining ring for anything taller. I wouldn’t be seeking to use them whilst actually moving, I’d only use them parked which is obviously safer anyway. What do you all have? I did a few searches but found most info / photos posted was in various pages. ![]() ⛽️🛢️⚙️🧰💪 |
The best cup holders come at the front of the MSS cubby box. Big enough, deep enough and in the optimum place whilst driving
![]() Wouldn't be without mine. |
