Home > Puma (Tdci) > Defender Puma 90 speedo drive ?
tankpeople
I'm in the process of lifting the body off the chassis to replace it with galvanised , most connections are undone now - its been quite tricky gaining access to a lot of the pipes and cables on the TDCI Shocked
The clutch pipe connection is behind the plastic wheel arch liner which I cut an access panel through , and the gearbox electrics are hard to reach etc etc.
I cant find the speedo drive - any pointers about its location and any other hidden gems much appreciated.
Post #1021519 17th Jan 2024 12:28pm
It's an electronic connection to a transducer located between the handbrake drum and the rear face of the transfer box, accessible from under the vehicle.
Post #1021525 17th Jan 2024 1:09pm
