![]() | Home > V8 > Straight pipe exhaust? |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 517 ![]() ![]() ![]() |
I’ve got a bit of a mongrel of exhaust bits on my 90 V8 due to the conversion, when I first fitted it I had a largely 300tdi based setup with the big centre box and small tailpipe box, I then changed the centre box for a smaller silencer I found in some scrap metal and welded the right flanges on and I’d say it’s a good balance all-round.
It’s got a decent bark when you put your foot down and a nice burble on idle but it doesn’t drone at medium load/cruising speed. ![]() Click image to enlarge Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
mediamab Member Since: 01 Dec 2021 Location: Matlock Posts: 58 ![]() ![]() ![]() |
Ah ok so yeah maybe just a smaller silencer could be the sweet spot then. Think I’m gonna stay away from a full straight pipe. Found some videos on YT, they sound great but I can’t imagine an hour drive in one!
Only part of the silencer ha but obviously quite a bit larger to the one you adopted!
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 872 ![]() ![]() |
Those look like mild steel. Usually ‘full’ exhaust means from the down pipe back. Not including the manifolds. |
That looks like stainless. Note the smooth surface, even though some is heat discoloured. You have some choices to replace. You either need to find or make up a section with the flanges, so you can bolt it back in. This will probably require welding. The other option would be to cut the flange of the pipe either side and then use a flared section to rejoin. Both would work. The flange is probably the better approach, but will need you or someone to be able to weld. In terms of silencers. A smaller “bullet” one will work or indeed something like a cherry bomb. A cherry bomb is just a compact glass pack silencer, usually painted red. Other smaller silencers can be glass pack too. Or you get chambered silencers. They will sound different. A glass pack is normally more crackly sounding while a chambered one tends to have a deeper more pronounced tone. Jetex sell silencers or have a loom on eBay eg https://www.ebay.co.uk/itm/335178630189?mk...media=COPY Remember to check your pipe diameter. The silencer can have bigger and use some step downs. But don’t go smaller as it will reduce gas flow. |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1885 ![]() ![]() |
Hah! Snap. I've lived with this for a while but my intention is definitely to change back to a centre silencer when I can find the time and inclination. I'm probably 60/40 on it. 30 - 40% of the time it can bring a smile to my face; most of the time I wish it was just a little quieter - but I do like the rumble of a V8. I've found myself (probably idly) wondering how hard or expensive it would be to get a switchable exhaust - calm and controlled for when that was needed;howling and wild when not...... but that probably won't happen! Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Thanks so much everyone! This is all so useful.
The eBay link for the muffler looks a good option. Unfortunately welding isn’t a skill I’ve tried but I assume if I take measurements of the pipes, the distance between the pipes with silencer removed etc then someone should be able to provide / fabricate the pieces quite easily? With the headers, is there any value in going stainless? I need to remove them and replace bolts and gaskets in the hope they’re the cause of the tapping noise I get when engines hot. |
I assume a kit such a tho below requires more than just to straight pipes to couple together? Ie welding still required?
https://www.ebay.co.uk/itm/385466852053?mk...media=COPY |
An exhaust shop should be able to fab up something with the correct ends. Either drive the vehicle down, or just take the silencer to them with the new one and ask them to build the ends to match the other. Obviously matching by eye might be hard, so fitment may require a little work, unless you get them to do it. I'd have thought most custom exhaust places would be favourable to a cash in hand deal for a small job like this. Years back I removed the rear silencers on my Jag XJ-S V12 and had a local company bend some straight pipe to match. One of the best mods I ever did to the car. |
Ive not used a clamp like this before. But it should work, assuming you the correct diameter, it would be instead of the flange. |
Yeah I’ll explore local places (haven’t lived here that long ha) but sounds like finding the right replacement and then getting someone to do the simple fab to match will work well and suit my wallet too!
So really if I had two straight pipes then it should be a straight swap? (I don’t currently but I could cut them down) |
Ah actually looks like that’ll still need welding. Seems to be a bunch of none welding solutions but feel like I’d rather it all be done right!
I did come across the below - which appears to be the only full kit. But whilst would be an upgrade to stainless wary of it’ll help bring out the rumble ha https://www.paddockspares.com/da4236-exhau...ts-wi.html |
If you do take the headers off, I would be interested in buying them. Although if I'm honest, stainless is more about looks than anything. Obviously should last longer too. |
