Home > Technical > Red Bison Heated Windscreen - How to test?
neverin
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi All,
I've fitted a Red Bison heated windscreen to my 2004 TD5 defender.
I tried it this morning but it didnt melt the frost.
The light comes on and the relay clicks when i press the switch and it stays on for about 10 mins but not melting the frost.
Tested it with the engine running even though it clicks and lights up when ignition is off.
Are there some multimeter checks i can do?
Any help greatly appreciated.
Post #1021010 13th Jan 2024 12:35pm
andy63
the timed relay operates another relay, and by the sounds of it that side of it is working fine... but you need to check the supply to that second relay..im afraid I don't know what fuse is involved in supplying that second heated screen relay..
Post #1021025 13th Jan 2024 2:51pm
neverin
This is the kit I bought.
Post #1021070 13th Jan 2024 11:18pm
neverin
Here is instruction diagram. Maybe I have a bad earth?
Post #1021073 13th Jan 2024 11:33pm
bankz5152
Multimeter on the windscreen connections. If theres voltage there it works if not then work your way back
Post #1021089 14th Jan 2024 9:55am
Balvaig
If it is installed as the diagram there is not much to check.
If there is power to windscreen connections then the screen elements have failed.
Check the earth, as it is possible that the switch light could illuminate if the earth is poor.
As the switch light illuminates then the fuse would seem to be ok, but you could replace it to be certain.
If there is no power to the windscreen connectors, then the control box may have failed.
Your multimeter is the solution here. Just work through the circuit.
Post #1021125 14th Jan 2024 12:58pm
neverin
So i've removed the cover to investigate and as you can see the quality of craftsmanship is not as good as first hoped. Anyway i've take some multi meter readings. Can anyone offer any support?
I've also done a reset as per instructions but there is still no voltage to allow the windscreen to get warm.
Post #1022701 27th Jan 2024 3:24pm
pistonfields
Switzerland
Had mine fail too. Changes are one of the wires are broken, they use very cheap materials. Sadly. Because the thing itself is way overpriced for what you find inside. I wouldn't bother trying to repair it but instead replace it with a timer relais circuit board from aliexpress. Costs next to nothing and has adjustable timing settings with buttons and displays. Will edit my post when I get home to include and example. Have replaced it myself and happy ever since.
/edit: I used a board like this one here. Programmable, but current only up to 15A. That's why I use it to trigger a normal relay to be on the safe side.
Post #1022764 28th Jan 2024 7:27am
Mo Murphy
I don't think the Red Bison brand has a particularly good reputation for quality ! I used the Mobile Centre harness which though quite expensive has worked flawlessly for the last 9 years.
50 Shades of Pennine Grey
Post #1022785 28th Jan 2024 11:02am
It's really not difficult to make your own harness and replicate the factory installation.
Post #1022787 28th Jan 2024 11:10am
neverin
what current would it normally pull? would it be over 15amp? the fuse fitted is 30amp
Post #1022825 28th Jan 2024 6:08pm
neverin
All working now. Voltage at windscreen. Found this same item on Amazon, ordered, fitted and now windscreen should work. Just need a frosty morning.....
Post #1023535 4th Feb 2024 3:23pm
