Home > Maintenance & Modifications > Erratic Temp Guage |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5731 |
You have a coolant issue if you have air in it.
The temp gauge isn’t a real reflection of temp, like most these days it’s controlled by the ecu. So works like a “proper” temp gauge up to about half way, then if the ecu detects an over heat, will immediately go straight to the RED. Possible you just have air in system such as heater matrix, but could be another issue such as failed head gasket. Are you loosing coolant at all? |
12th Jan 2024 3:08pm |
SimonMB Member Since: 12 May 2023 Location: Palma Posts: 2 |
Thanks,
Yes I noticed some coolant loss today. It seems like it came from the top of the bottle. Cap was tight but maybe not sealing correctly. I suppose no heating in the cabin also points to something coolant related. But also odd the gauge goes completely dead sometimes I’ll keep investigating… |
12th Jan 2024 7:14pm |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 399 |
The heater matrix can be a pain to bleed, I ended up loosening the clamp on the return to try to make sure the matrix was full of coolant and not air
May be also worth checking the connections in the dash to your speedo and temp gauge, the speedo damps the temp gauge in a td5 |
13th Jan 2024 11:49am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
Speedo doesn’t get involved with temperature gauge. Fuel gauge yes, not coolant.
The sudden jumps could be a loose connection, either at ECU or cluster pack end. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
13th Jan 2024 1:08pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2247 |
The speedo only modifys the temp gauge reading in ROW vehicles that were 300tdi vehicles built in the time of the TD5 with TD5 dashes.
13th Jan 2024 4:23pm |
