Home > Td5 > Fuel regulator 10p or 15p
Dover mike
England 2000 Defender 90 Td5 CSW Arrow Red
Good afternoon everyone can you help me I have a defender td5 10p 2000 and need to know if my engine has a 10p head or 15p head I need to replace the fuel regulator
Post #1020953 12th Jan 2024 7:32pm
rustandoil
This is 15P... Hope this helps
Post #1020954 12th Jan 2024 7:59pm
landy andy
Your looks 10p as it has 2 pipes attached to it. A 15p has 3 (2 hoses, and 1 pipe). The pipe runs across the side of the engine and can easily be seen.
Post #1020989 13th Jan 2024 8:58am
Dover mike
thanks mate the thing im dont understand is that some kits show the regulator with a pipe on the end and some show no pipe on the end and i cant see mine as im using the LR every day and dont want to disturb it as its already leaking is it just a case of blocking the pipe off if not needed
Post #1020996 13th Jan 2024 9:40am
Dover mike
was looking at this rebuild kit what your thoughts
Post #1020997 13th Jan 2024 9:42am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Rebuild kits are good those parts are decent (I used that kit). The only issue is sometimes the rebuild leaks again. Its worth a try. The little pipe on the FPR is a drip pipe, face it so you can see it when you install it (horizontally maybe)
Personally I would install a new assembly. I did a kit and it lasted three years until it leaked again. A new assembly is still going after four years.
Good luck Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1021024 13th Jan 2024 1:44pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
I've used these X8R kit in the past on my own 110 and have one in the workshop waiting to go on a neighbour's 90. I'd highly recommend them and they come with the necessary gaskets to match up with the difference between the 10P and 15P versions. No leaks on mine 5 years later.
Post #1021051 13th Jan 2024 6:39pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
I recommend use genuine flat gasket between engine head and body of the regulator. In some repair kits these gaskets are not good. Genuine gaskets are cheap. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1021086 14th Jan 2024 6:04am
NickMc
It’s 10P in your picture. Think You need a rocker cover gasket/rear cam seal from the look of it too maybe.
Post #1021146 14th Jan 2024 1:45pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
My PRV is leaking so I need to order a replacement. I'm going to get the whole assembly. Mine is a 10P (MY2000) 2 pipe.
LR Direct has the 2 and 3 pipe, but I am curious abut the description. 2 pipe is "non Euro 3 specification" and 3 pipe is " Euro III Td5 engine."
What is the difference between the 2 engines, never heard of the "Euro specification" before. Am I correct in assuming non Euro 3 is a 10P and Euro III is a 15P?
Here's what I'm seeing under the bonnet, and on the ground. Actually easy to see fuel dripping out the block.
 it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #1022330 23rd Jan 2024 11:29pm
4RF RDS
Have you snugged up the bolts? Its very high pressure and people often do not torque the FPR assembly bolts properly.
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #1022336 24th Jan 2024 2:37am
CDN38
Everything was torqued to spec when the AMC head was installed. From what I see it's leaking out of the diaphragm. it's a Landrover thing...
Post #1022337 24th Jan 2024 3:24am
You want to sort that leak fairly quickly as well.... mine leaked the same, down through the joint bwteen the bellhousing and the engine, and soaked the clutch in fuel, which then started to slip. Rolling Eyes
Post #1022341 24th Jan 2024 8:34am
Penfold_6290
One visual difference between the two is the Euro III engines had an EGR cooler mounted on the front of the engine, visible just below the acoustic cover behind the fan. It's a cylinder about 25cm long with 2 coolant hoses connected.
I think Euro III was from 2002 onwards, it's an emissions thing.
Picture credit to Geobloke
Post #1022376 24th Jan 2024 12:09pm
TexasRover
I understand the injectors are different between the 10p and 15p. In addition to the cooler the EGR valve has two actuators, one to close the air inlet and the other to open the exhaust gas intake. Instead of just the one on the 10p.
For sure this must have to do with emissions which, as we know from Volkswagen, can be a little academic
Post #1022380 24th Jan 2024 1:04pm
