Home > Tdi > Lazy start and rough idle when cold.
Mean Green
I am looking for suggestions - my 200tdi 90 cranks for ever before it splutters into life. Then it idles rough and 'hunts' for several minutes.
It has a new lift pump and recently changed injector pump. The battery is good and has also been on the C-tec charger to make sure.
In my head it feels like it is a fuel starvation issue - as if the fuel had drained back to the tank and had to be sucked back up to the injectors before it will start. (probably over simplistic, but it feels like it wants to start but doesn't have any fuel).
Probably a related issue - there is a fair amount of white smoke and smell of unburnt diesel when it first starts. Once is it going it runs fine.
Post #1019374 27th Dec 2023 2:26pm
Retroanaconda
First thing to check is the fuel leak-off lines on the injectors, either perished hose or loose banjos depending on age. Very common on Tdis, and causes this issue if left for more than a few hours.
Post #1019378 27th Dec 2023 3:04pm
Mdm
was the injector pump rebuilt?
easiest way to double check if fuel pipes are drawing air is feed from a small bottle of fuel in the engine bay. if it starts every time this way you know you have an issue on the feed side of things.
if not then pump or up stream of that bit or on the return side
Post #1019382 27th Dec 2023 4:47pm
8619simon
Wales 1995 Defender 110 300 Tdi CSW Epsom Green
Re: Lazy start and rough idle when cold.
Is the timing OK? I had the same symptoms especially the white smoke on start up which then disappeared after a few minutes. Turned out the timing was slightly retarded.
Post #1019388 27th Dec 2023 6:35pm
Mean Green
Thanks for the suggestions. I will start with timing and work out from there.
The timing was checked after the engine was re-installed during the re-build, but wont hurt to double check.
Post #1019391 27th Dec 2023 7:00pm
johnlad
Mine was like that when the glow plugs had all failed.
Post #1019409 28th Dec 2023 8:42am
Fossil
United Kingdom 1997 Defender 110 300 Tdi CSW Coniston Green
I would agree, glow plugs have to be a suspect and are easily checked for power getting to them, and continuity
Post #1019413 28th Dec 2023 9:40am
Mean Green
Can someone sense check my thoughts on the 200tdi timing, it has been a long time since I last did this and cant exactly remember the details.
Am I right in saying that for the timing to be right, there are three things that can be checked...
1. the TDC line on the pulley should line up with the casting on the crankcase
2. the timing pin should slip into the slot on the FIP
3. the timing pin should slot into the slot on the flywheel.
I started by lining up the pulley and TDC line - but the slot on the flywheel was not alingned with the wading plug hole and the pin would not go into the FIP. So i lay underneath looking up into the wading plug hole and had someone turn the engine until I could see the slot. When this was lined up, the pin also slipped into the FIP, but TDC was about 20mm or so away from the casting mark.
Am i right in thinking that this would suggest that the timing belt has either slipped or has been misaligned when fitted and to fix it is basically a timing belt change ??
Post #1020344 6th Jan 2024 10:32pm
bodstruck
If it was a timing issue would it not run poorly all the time?
You may have eliminated the glow plugs as a cause already but the symptoms you describe are exactly the same as i had on my Puma some while ago. New glow plugs solved it.
Post #1020356 7th Jan 2024 8:05am
julian
United Kingdom 1994 Defender 110 300 Tdi CSW Alpine White
My vote is on drain back. The hole could be anywhere from the injector leak offs to a poorly sealing olive on the lift pump tails.
I always advise making up a bit of fuel line with clear nylon pneumatics pipe so as you can physically see any air. Failing that any way of connecting the return from the back of the IP to a short hose that you can dunk under the fluid level in a clear (coke) etc bottle and watch for air bubbles.
To me your symptoms sound just like something not sealing up quite right and the hole not being big enough to cause issues when running, but just large enough to cause drain back.
Post #1020884 11th Jan 2024 11:26pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Rough Idle
Hello,
Does the rough idle and smoke clear altogether?
We have had a similar issue on a 300tdi, the keyway on the crank pulley was worn so the engine was able to minutely retard and advance itself, just fractionally.
Made for lumpy idling when starting, when driven "normally" under load it was fine, then if you idled for a long-ish period or spent a long period coming down hill on engine braking the issue would return.
Was a pain to track down.
Chris
Post #1020921 12th Jan 2024 1:02pm
Mean Green
So had a minor disaster.
I have owned the 90 for 25years this year and it occurred to me that I cant remember ever changing the glow plugs (largely because it never really needed them and started on half a turn of the key everytime).
So given the advice above, I thought, might as well change them for an easy fix... whats the worst that can happen!!! .. so it turns out the worst that can happen is a sheared glow plug - half of which is stuck in the head. So it now needs stripped down and the head off to get the remains of the glow plug out. Rolling Eyes Big Cry
Post #1022212 22nd Jan 2024 6:02pm
That sucks, thatโ€™s a real concern with glow plugs it really is.
When was the fuel filter last changed? $W33T $0U7H3RN $UG4R
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #1022215 22nd Jan 2024 6:17pm
julian
I've been driving mine with a stuck tip for some time. I keep thinking it will shoot out at some point, but it has not.
I doubt yours will move at all, but worth soaking in wd-a-like and then going for a spirited drive before pulling the head?
Post #1022288 23rd Jan 2024 2:01pm
There are kits and tools available for the removal of broken and stuck glow plugs, it is a very common problem.
The principle of operation is as described here (not that this article describes an OM606 though).
https://www.instructables.com/How-to-remove-Broken-Glow-Plugs/
Another explanation:
Post #1022291 23rd Jan 2024 2:37pm
