![]() | Home > Puma (Tdci) > High Pressure Hissing Noise |
Check all hose clamps, hoses for splits and the intercooler for splits as well. If the intercooler has a popped weld it is often noticeable by a weep or oil from the split.
You haven't recently added a snorkel or changed the snorkel top have you? These can increase induction noise lose to your head. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20729 ![]() ![]() |
Check the torque of the fixings of the air inlet manifold above the MAP sensor to the block, all of them against the WSM torque settings.
Signs of oil deposits / blow by residue can be a sign. Just something to look at, 10NM rings a bell to me on the manifold to block bolts but consult the WSM. I found that one bolt was 7NM, the rest were torqued correctly on one fixing nearest the front which meant I had a minor boost leak for a long time. That ever so slightly loose bolt was enough to induce a little boost leak, the tell tale sign was oil deposits around it but even then wasn’t so easy to find. Also check hoses and Intercooler too as suggested, and also the steering column shaft for rubbing on the hose turbo side as well, it’s seriously close. ![]() Good luck. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
That reminds me. Check the little o-rings on those sensors as well. If one is broken it could allow air to bypass the sensor and hiss under load... Didn't think of that until the above post
Ah yes, it was the MAP sensor ‘o’ ring I was thinking it may have been but wasn’t in the end but is known to do so.
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2246 ![]() ![]() |
Also worth checking the airbox lid is correctly fitted, that the air filter is seated correctly and that there are no cracks in the airbox.
mwestcrew Member Since: 09 Dec 2019 Location: South Warwickshire Posts: 287 ![]() ![]() ![]() |
Thanks guys.
Some useful additional things to check over and above the usual things that I have already checked. 2011 130 Utility Body 2005 110 Van |
Daphne Member Since: 22 Nov 2023 Location: Kent Posts: 25 ![]() ![]() ![]() |
Turbo to manifold flange nuts are tight and gasket is good, mine started doing it when the bottom flange nut had mysteriously disappeared 😀
