Home > Modifications & Maintenance (L663) > Roof Rack Options |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1398 |
I have the LR rack. Think it's noisy and not that practical because of the aero bars. I'm probably going to get either the Front Runner or Prospeed rack. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
9th Oct 2023 8:03am |
ODPA Member Since: 06 Jul 2023 Location: Northwest Posts: 86 |
Any chance you have a link for the prospeed rack? I do not see them having a rack available for the defender. Looks like a cool product though when looking at what they have for Toyota vehicles.
9th Oct 2023 11:59am |
Here you go:
https://prospeed.co.uk/products/2019-prese...-roof-rack Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
9th Oct 2023 12:06pm |
Thanks. That was definitely not the prospeed site I was on. Maybe UK vs USA. Anyway thanks for the info I am hoping this will grow into a good list of options to help others in their look.
9th Oct 2023 12:43pm |
After several months of looking and considering I am back at this. I have been taking a serious look at the Prospeed Aero Expedition rack and the Expedition One Mule. Anyone have a real world experiment with either of these? I initially started this search thinking I would buy the Voyager Rack but I have the cloth roof I think that option will be noisy. Think one of the others may be the best options for wind noise. I also like that they are low profile.
8th Jan 2024 12:14am |
Decision made. Ordered Prospeed Aero with a few accessories to go with it. Hoping it does not take too long to arrive. Will share thoughts and pictures once it arrives.
10th Jan 2024 5:32am |
Be interested to see how you get on. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
10th Jan 2024 10:40pm |
I will post as the process moves along. So far I would say the customer service has been outstanding. Calvin at Prospeed reached out this morning after I placed my order last night. Wanted to give me info on their inventory status. One item I ordered they are short on he offered several solutions to meet my needs quickly. After a couple emails we established a plan. I was impressed. Will have a little wait for a couple parts but I am ok with that and appreciate the upfront info and desire to make sure I was satisfied.
11th Jan 2024 1:26am |
stevemfr Member Since: 18 Sep 2022 Location: Strasbpurg Posts: 138 |
12th Jan 2024 12:25pm |
Will do. Is supposed to be here Thursday. We will see with all the bad weather we are having. Doubting it will be on time. On generator power and have not left home in two days thanks to freezing rain and my lack of desire to go play with all the idiots on the road.
15th Jan 2024 4:23am |
Lightwater Member Since: 28 Jun 2020 Location: Sydney NB Posts: 72 |
On the Freelander I had a roof platform, but ended up removing it, even after completely rebuilding it to exactly suit the Freelander. Unless you are using it as a "photographic" position, they are a waste of roof payload. Ended up using 4 crossbars. Platform less 2 extra crossbars saved 16kg. The whole roof setup is far better than a platform. Everything is easier to get on & off the roof. 10L fuel containers is as much as I want to regularly lift on & off the roof. Click image to enlarge Click image to enlarge Custom 4 x 10L fuel holder (another 2 x 5L in spare wheel). Click image to enlarge Click image to enlarge Click image to enlarge Bracket to hold sand tracks. Click image to enlarge Click image to enlarge Custom bar between to crossbars to clamp down spare wheel, 5083 alloy (It's bolted into a block inside each crossbar, not actually to the crossbar). Click image to enlarge Custom bracket to store solar panels on roof (6 x 20watt, custom hinged & stand). Main supporting brackets between 2nd & 3rd crossbar are 10 x 50mm aluminium fat bar which I got an engineering shop to bend. Click image to enlarge All the holes were tapped on second plate & Nyloc nuts used, 316 stainless M4 & M6(mostly) Allen bolts. Most of the aluminium is anodised. Some parts are 316 stainless steel for extra strength. Hopefully some ideas here you can use for a better setup than a platform. Visitor - Freelander owner |
16th Jan 2024 1:31am |
Nice custom mounts for a ton of items. Great use of the spare to gain some extra storage though I will admit I don’t think I will ever relocate the spare to the roof as I don’t want to lift it up there. The Jerry can mount is very cool. I am sure I will do some custom stuff as well but hopeful that the Prospeed Meets the majority of my needs which I think it will. Most likely it will be a place to Mount some lights, an awning, a few Jerry cans, and a couple Roam cases.
16th Jan 2024 3:39am |
I only have the spare on the roof as it is the second spare for the Australian outback. You simply need 2 spares. So 1 has to go on the roof. Also TPMS, tyre repair kit & compressor (3 ARB compressors in parallel in my set-up to be quicker, up to 90amps). Any thicker than 3mm you need to get it bent at an engineering shop.
2 spares on roof. Click image to enlarge Click image to enlarge Tip: Hand bending 3mm aluminium flat bar, heat with heat gun (reduces stress cracking) for 2 minutes in bench vise, then quickly bend over with block of wood (have a bucket of water at the ready just in case you burn yourself so you can shove your hand in quickly). P.S. A heat gun is great for soldering Anderson plugs. Visitor - Freelander owner |
17th Jan 2024 1:59am |
Great advice and work. Very cool setup specific to your environment that you travel. What is the tube for? Water/shower?
17th Jan 2024 3:05am |
