Home > Maintenance & Modifications > Under cubby spare wiring plug
Neil Jackson
United Kingdom 2014 Defender 110 Puma 2.2 HT Fuji White
Hi I'm mid fitting a cabin heater and using the cubby plate as the spot for the heater, cheap Chinese, will update how I get on soon..
I found this unused plug through the plate large rubber grommet etc, and can't for the life of me work out what it's for, can someone help me out, it's currently bagged up and stashed underneath.
Post #1020346 6th Jan 2024 11:14pm
Ianb
United Kingdom 1998 Defender 110 300 Tdi HT Alaska White
This was sent to me when I asked about a particular cable I found, I don't know what yours is, but apparently by knowing the wire colours and the plug colour etc, you can work out all sorts...
But hopefully someone who knows will be able to help you straight off the bat.
TexasRover wrote:
Yep fantastic that this information is so readily available on LRWORKSHOP:
For those that have not yet, look here:
https://www.lrworkshop.com/wiring-diagram/defender-1999-td5
https://www.lrworkshop.com/connectors/defender-2002my/colour
You can work out you entire (factory) wiring, plugs, earth connections the lot.
Also something I recently learned here on Defender2.net is that on the wiring diagrams, for each wire the last large number is the length of the wire in mm
 The Yeti - 110 Camper https://www.defender2.net/forum/topic90308.html
Youtube - https://www.youtube.com/@YetitheDefender
Instagram - https://www.instagram.com/yetithedefender/
Post #1020350 6th Jan 2024 11:31pm
Neil Jackson
Thanks Lanb, I'll dig around in there and sure it all will come apparent
Post #1020352 6th Jan 2024 11:40pm
Martin
Site Admin
For the optional subwoofer fitted on the back of the cubby box  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1020353 7th Jan 2024 12:00am
Neil Jackson
Thanks Martin, it can stay where it is, I won't be having one just yet
Post #1020354 7th Jan 2024 12:01am
