Home > Maintenance & Modifications > 2.5 NA Removing DPS Pump
nortm
United Kingdom 1986 Defender 90 2.5 n/a Diesel PU Buckingham Blue
Hi all,
Am going to be removing the DPS pump from my 1986 2.5 NA. Without removing the entire front case, I am wanting to remove the small access cover at the front and lock the pulley in there. Has anyone done this before with out the special tool mentioned in the manual? If so what did you use?
Thanks,
Post #1020341 6th Jan 2024 9:15pm
