Home > For Sale & Wanted > [For Sale] Second Row Door Check Strap Kit/Parts |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2227 |
I have a surplus kit from SP4x4 for RH second row door, as per https://www.sp-4x4.com/BFH710150_p/jwp1408.htm . All still in packages.
£15 posted or £10 collected from M1 J31 Also have a pair of the brackets which fit to the rear footwell kickplate which the second row door checkstraps attach to. Both brand new in package (MRC4753 & MRC4754). £10 posted or £5 collected from M1 J31 Cheers, Steve Click image to enlarge Click image to enlarge Click image to enlarge 02' 110 TD5 Double Cab Rebuild Thread |
3rd Jan 2024 10:23pm |
Hi Martin,
No problem, i will measure for you, the parts catalogue shows the same part numbers (BFH710140/BFH710150) for both older and newer doors (1987-2016) though. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
5th Jan 2024 9:07am |
hxk494 Member Since: 29 Apr 2013 Location: Edinburgh Posts: 239 |
thanks Steve, much appreciated.
I know part # covers both new and old but I've got new style doors and old check straps fitted and I'm convinced they don't open as far as they used to/should. No rush for the info. Martin. 1996 300Tdi Defender 110 |
5th Jan 2024 2:29pm |
Afternoon,
Measured it today and its approx 195mm centre to centre (not measuring along the curved arm). If that helps? Cheers, Steve Click image to enlarge 02' 110 TD5 Double Cab Rebuild Thread |
7th Jan 2024 1:54pm |
Thanks, just checked mine and they appear to be 185mm so not quite sure what’s going on there.
Not sure if 10mm difference will do much to door opening, think perhaps I’ll look I to the door opening extension kits the likes of YRM sell - that would cover both sides for a similar price with hopefully guaranteed results! Appreciate you measuring but think I’ll pass on this occasion Click image to enlarge 1996 300Tdi Defender 110 |
7th Jan 2024 5:56pm |
julian Member Since: 17 Feb 2017 Location: Devon Posts: 106 |
Steve,
If Martin is "out", could i take these bits, please? Thank you. |
3rd Feb 2024 7:10pm |
Just got the door parts in the post - all looks good.
Thanks to @rallysteve for a smooth transaction. |
15th Feb 2024 1:29pm |
