![]() | Home > Puma (Tdci) > Fuel consumption in thick sand |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2463 ![]() ![]() ![]() |
My guess. 29x0.4 Puma 110" SW
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17698 ![]() ![]() ![]() |
There are so many variables it is an impossible question to answer. A laden vehicle on deep soft sand , it wouldn't surprise me if it dropped to 5mpg.
How soft? How laden? BFGs (even though you don't say what type) aren't sand tyres so won't be ideal. I would be very careful and take local advice and also check consumption before you pass the point of no return. |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1224 ![]() ![]() ![]() |
I have done a bunch of sand driving (beach and desert). This is hard on man and machine. You need a lot of focus, it's not fast and with the extra load and low speed, not to mention typical hot environment, your cooling system needs to be top notch.
Personally I never worried too much about range. Start with a full tank and limit your time in the sand. Are you going to cross a desert you are worried about range? |
