![]() | Home > General & Technical (L663) > Rear seats really stiff to slide |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3034 ![]() ![]() |
Try spraying silicone lubricant on the runners.
holtenc Member Since: 15 Aug 2023 Location: TX Posts: 28 ![]() ![]() |
The springs are indeed stiff when new. I have found that over time they loosen up a bit with use. I've got a family of 5 so the middle row is moved almost daily and the spring tension is noticeably less stiff compared to when new (6-7 months ago).
