Home > Puma (Tdci) > 2014 specification.
Howard
United Kingdom 2012 Defender 110 Puma 2.2 PU Alpine White
2014 specification.
I would be grateful for help with understanding the specification of my 2014 ninety hard top.
The truck is a good spec with both comfort and winter pack as well as A/c and alpine blue tooth. Vinyl instead of carpet.
But I have noticed most if not all other 90 hardtops of my year appear to have roof glass and rear quarter light windows. Are these all XS models and mine a commercial van spec. Or do I have last of the old spec?
Last point. The ride is very hard . Is the heavy duty suspension option standard on the hardtop models?
Post #1019469 28th Dec 2023 8:55pm
MK
As for suspension you could check the colored stripes on the coil springs. Then you can check it out with the detailed information available in this forum. Anyway the 90" is a lot choppier than a long wheel base Defender.
There are tons of threads about this topic in this forum. Puma 110" SW
Post #1019505 29th Dec 2023 9:27am
Dinnu
Fitting NRC2119 with isolators at the back if a Puma HT made the ride softer while maintaining the same height. Load carrying capacity could be reduced though as they sag more for the same weight.
I fitted them to my SW and improved a bit, but not as much as with the HT as my rear springs were originally dual rate. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1019506 29th Dec 2023 9:34am
RobKeay
Carpet was an optional extra for clean people. My XS has the better wipe clean stuff.
I got mine new in 2014. You could buy a base model and have all the options you wanted. XS had grey painted grill and light surrounds.
https://autocatalogarchive.com/wp-content/...014-UK.pdf
Post #1019547 29th Dec 2023 3:52pm
