Home > General & Technical (L663) > JLR modifications? |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1140 |
Interesting, not seen a Ladder fitted over a Molle plate before .........
Click image to enlarge ........ until I did it myself only last week (the ladder did need two new holes drilled into the top mount bracket) |
22nd Nov 2023 3:50pm |
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 269 |
I would say they’ve tricked it to go into fully extended mode which happens when the vehicle grounds out. Though there’s probably a setting in Pathfinder that allows them to do it . 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
22nd Nov 2023 5:15pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2832 |
l am sure that JLR will modify and refine the Defender, after all it's now been out three years, l am surprised there haven't been more updates
22nd Nov 2023 5:40pm |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 154 |
Interestingly, that front bash plate is completely different to the factory version and it appears to have rock sliders fitted. Current vehicle: 2020 Defender 110S Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
22nd Nov 2023 9:32pm |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1398 |
It might be a prototype mule. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
22nd Nov 2023 10:11pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2760 |
Interesting… a lot going on there:
- definitely more than just electronically raised suspension… - US spec? (Lights on fenders) It’s LHD anyway Maybe something for a film or something? Or a very specific motorsports application? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
23rd Nov 2023 12:37am |
gurka Member Since: 12 Dec 2021 Location: Texas Posts: 1 |
I would say that it has a subframe lift. I am seeing these more often here in the US. That one looks to be at least 5 inches - I am guessing a subframe as the bash plate on the front had to be extended down to the subframe. I have a 2inch subframe with sliders and 18's myself.
@LR Nuts - where did you get the molle plate. Great idea! |
26th Dec 2023 11:17pm |
google POWERFUL UK
here is the link https://www.powerfuluk.com/collections/new...urr_page=2 I also have the LH molle with (removeable) Side Carrier Box attached Click image to enlarge |
27th Dec 2023 9:35am |
