Home > Off Topic > 4wd with good tyres Vs 2wd with snow chains |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1090 |
I have done s lot of snow driving in Norway, Canada and Alaska. Snow chains are not viable for driving any distance, they are there to get you out of a hole and you are pretty deep in it if you have to take snow chains out. Think more getting out of a deep snowy verge onto a main road.
You kinda screwed up already at that point, and be the laughing stock of the locals. Typically you would have to deal with compacted snow which is less slippery than black ice, but can easily catch you out. You be relying on having the right tires, the right driving technique (speed) and experience. For normal travelling 4 wheel drive is not really all that beneficial. In fact in Norway the insurance premium is higher for 4 wheel drive cars as they are involved more in accidents. Having 4 wheel traction and 4 wheel braking means you tend to go faster and further (up the hill) so your braking will be less effective once you need it. Basically a 2 wheel drive car will show the limits of safe driving earlier with still having 4 wheels left for braking. I used to get by fine with 2 wheel drive and when I had a 4 wheel drive car it would mainly be useful for "the last mile" to a cabin in the woods, which you know in advance. It sounds a bit boring but when you live with snow you just adjust your driving and wait for the snow storm to be over and the roads to be reasonably cleared.. |
18th Dec 2023 6:25pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17470 |
The literal answer is that a 2WD with chains will run rings round a 4x4 without chains under many conditions, but as noted above there are practical drawbacks to chains (and constantly fitting and removing them is but one).
Many years ago (about 40) I'd gone to an AWDC trial at a site I cannot recall in my 1600 Cortina. The parking field was quite steep and very wet grass, and when everyone started to leave almost everyone was having real trouble. Several vehicles simply slid to the bottom of the hill, at least one S1 Land-Rover fell over at the bottom. I was getting "no chance" pitying looks as I started my 2WD "Reptina" and a small crowd gathered to watch me fail spectacularly. I however fitted the tyre chains I had in the boot and was then able to drive up the hill and out with no wheelspin whatsoever, past several Rangies and the like, which were slithering all over the the place. It was a satisfying moment! There have been several occasions when I have chained up on a Defender or S1, but only one has been on tarmac. That was a long hill which had a sheet of thick ice from top to bottom and would have been impassible upwards and lethal downwards without either chains or possibly studded tyres. |
18th Dec 2023 7:43pm |
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 869 |
A point to consider with twin rear wheeled vehicles in extremely cold conditions is that snow can compact between the wheels, turn to ice and build up. Then it's out with the pick-axe...
Peter |
18th Dec 2023 7:58pm |
Chains for twin wheels are also harder to obtain and tend to be significantly more expensive than singles. They are also harder to fit.
18th Dec 2023 8:13pm |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 483 |
Thanks all for the replys!
18th Dec 2023 11:03pm |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 760 |
[url] ?si=PuV2Ulqg_lrx_zQQ Worth a watch. [/url] |
19th Dec 2023 2:56pm |
Don't go anywhere near snow "socks" if you want to retain any self-respect or credibility!
They exist only to allow people to make fools of themselves on social media. |
19th Dec 2023 3:38pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5741 |
Even with single chains on double drive wheels you are going to be able to get to most places. Even in very icey countries they use auto chains which only work on the single inner tyre.
4X4 and full chains will get you very far, and able to have fun. Click image to enlarge Click image to enlarge |
19th Dec 2023 4:14pm |
